integra over heated
Old Jun 30, 2009 | 09:18 AM
yzhang's Avatar
Default integra over heated
bros,
my integra is over heated when in idles. whenever i am not accelerating, the temperture is going up, when i hit the gas, temperture going down. it shows on my dash meter. what is the problem?
Old Jun 30, 2009 | 09:32 AM
nicgep's Avatar
Default Re: integra over heated
Check to see if your fans are running, if the wiring is faulty, or a blown fuse.
Old Jun 30, 2009 | 09:49 AM
yzhang's Avatar
i checked the fan, its working propertly. antifreeze coolen is checked too. forgot to mention, i am from las vegas, its about 110 degree now in the daytime.
Old Jun 30, 2009 | 10:13 AM
b20acura's Avatar
faulty thermostat? try flushing your radiator and changing the thermostat. maybe your coolant temp sensor??
Old Jun 30, 2009 | 10:36 AM
TOO MUCH TORQUE's Avatar
you probably have induced air in the system. bleed the coolant system
also dont drive the car until it is fixed, warped head is last thing you want(heaadgasket)
Old Jun 30, 2009 | 12:42 PM
ruffrhyder's Avatar
My car was doing the same last summer. Here is cali it was 105-115. My coolant was a bitl low and I had some air in the system. Bleed the coolant of any any and make sure your rad. fins are clean of bugs and debris.
Old Jun 30, 2009 | 04:03 PM
94 ls-r's Avatar
I agree. Use a water hose with low pressure cause ya dont wanna ben the fins and wash it out. You can aslo pull the bottom hose and flush the inside too!
VenomRx
Nov 16, 2013 03:13 PM
junior_tm
Mar 1, 2012 11:40 AM
Acurasforlife
Aug 31, 2011 03:03 PM
VTecLude1994
Jun 24, 2006 09:24 PM
PyeeK
Mar 17, 2006 11:55 PM
