Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
07 LX hesitation
Old Jun 30, 2009 | 09:01 AM
StolenTeg's Avatar
Default 07 LX hesitation
Got a 07 LX with 70k miles on it, sometimes it would hesitate and sometime it drive fine.
Does this sound like the filter is getting clogged up in the tank?
Old Jun 30, 2009 | 09:29 AM
ironworker's Avatar
Default Re: 07 LX hesitation
Any mods on your car? Can you elaborate a little more on your story.
Old Jun 30, 2009 | 09:31 AM
StolenTeg's Avatar
No mods, 100% stock.
No CEL or anything, it would drive normal but than stumble/hesitate at times
Old Jun 30, 2009 | 09:32 AM
brian...'s Avatar
Geez 70k on an 2007?
Old Jun 30, 2009 | 09:52 AM
NMZ's Avatar
NMZ
transmission?
Old Jun 30, 2009 | 11:03 AM
FijiBlueFG2's Avatar
Road House
What, you mean you don't drive 100 miles per day, including weekends?
Old Jun 30, 2009 | 12:27 PM
chiggin's Avatar
70k is nothing. There is a guy on the ocho that has well over 300k on his 8th gen civic.
OP...I would start by replacing your fuel filter. Even if that isn't the problem, replacing it at 70k miles is a really good idea. Then I would check the air filter to make sure it doesn't need to be replaced. This should solve your problem, but let us know what happens.
*edit: Another thing I just thought of...if changing the fuel filter doesn't work and the air filter is fine, you should also check your spark plugs before you start to get worried. Good luck and let us know what happens.
Old Jun 30, 2009 | 02:48 PM
Road House
And he's a dummy for working a job that is 108 miles away from his house.
Old Jun 30, 2009 | 05:32 PM
ironworker's Avatar
You gotta put food on the table mang. In ironwork im always on the road and when work is slow you drive where the work is. Most i drove in two months was like 10k 250ish round trip to make a buck.BTW its probly on 54 miles from his house.
Old Jun 30, 2009 | 05:46 PM
Road House
Fair enough.
If that's the case, he must go home for lunch.
Old Jul 2, 2009 | 07:43 PM
Machine1's Avatar
Are you sure the hesitation isn't just from the electronic throttle?
How long have you had the car?
tortis
Jul 25, 2012 10:38 PM
brutekiller787
27
Feb 18, 2009 04:10 PM
teletekman
May 12, 2008 01:53 PM
EvenStar
Nov 20, 2007 09:40 PM
H.crx-si
Jun 30, 2005 11:24 AM
