15a fuse in 7.5a fuse spot
Old Jun 30, 2009 | 04:09 AM
CheddarPopcorn's Avatar
New User
Default 15a fuse in 7.5a fuse spot
i have a 1996 honda accord and the back up (radio) fuse is 7.5a and my staero is 15a so if i was to put a 15 or 10 amp fuse in would it be any better for the staero or could it cause dammage
Old Jun 30, 2009 | 06:34 AM
uberEFtuner's Avatar
Default Re: 15a fuse in 7.5a fuse spot
Bigger fuses will not help anything. If there is a short the wires, it will now melt or burn before the larger fuse blows.
If the fuses are blowing you should run a fused wire from the battery to the radio. If the new fuse on the new wire blows, then you have a bad radio.
Old Jun 30, 2009 | 10:53 AM
GhostAccord's Avatar
Don't forget that your ECU is also on that 7.5A back-up fuse as well. Not advised to start upping the fuse just for a stereo. Your stereo should have it's own in it anyway. If it is a 15A you won't have to worry about frying it on a 7.5A circuit. I'm no stereo guru by any means. I just installed my 15A stereo using the 7.5A circuit and had no problems. If your stereo actually requires a 15A circuit you should find one to wire it up too.
dhealey
Honda CR-V & Element
11
Jun 5, 2024 06:31 PM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
merch1
Mar 6, 2005 11:07 AM
TheAutoboxer
Apr 13, 2003 10:40 PM
PatrickGSR94
Apr 6, 2003 05:46 PM
