MY hood wont close!!
Old Aug 21, 2002 | 06:28 PM
zcivic91's Avatar
Default MY hood wont close!!
dam i was pulling out my a/c fan and tht cross piece where the hood latches. i put everthing back the way its supposed to be.now it will not close...wtf is wrong!!
some please help i need to drive it...is it safe to drive with it not fully shut
Old Aug 21, 2002 | 06:29 PM
dumbchild's Avatar
Default Re: MY hood wont close!! (zcivic91)
if it latches - but doesn't close completely - bungee cord it and drive SLOW!
if it doesn't latch at all - chain it shut.
Old Aug 21, 2002 | 06:37 PM
zcivic91's Avatar
Default Re: MY hood wont close!! (dumbchild)
haha..anyone esle got a better idea
Old Aug 21, 2002 | 06:45 PM
johnzm's Avatar
why isint it closing, is it even lining up with the hole?
Old Aug 21, 2002 | 06:46 PM
pelotudo's Avatar
do you hear any latching at all? And did you move the latch at all when you did it?
Old Aug 21, 2002 | 06:48 PM
big pete's Avatar
take off the hood
Old Aug 21, 2002 | 07:03 PM
zcivic91's Avatar
Default Re: MY hood wont close!! (big pete)
na..i put everthing back stock...is there some adjustment i need to make??
Old Aug 21, 2002 | 07:04 PM
whatREDLINE's Avatar
take off the hood
Old Aug 21, 2002 | 08:58 PM
flat-blk-HB's Avatar
Try adjusting the spring on the Hood. It is a flat head adjust it outwards and that might help. Dont go too far out or it will not shut just keep adjusting it and eventually it will work. But I dont understand why it is not closing corectly. Is the hood latch cable messed up or twisted anywhere? Try adjusting the 4 bolts that hold on the crossmember with the latch on it. Hopefully this will help!
_Brandon_
Old Aug 22, 2002 | 05:54 AM
WuShu's Avatar
New User
Default Re: MY hood wont close!! (ED6)
dude look to see what its hitting, if it isnt closing its because its hitting something. diagnose it, there is no way anyone could figure out why your hoods not closing being as vague as you are. Is it hitting anything? is it latching? does it line up? any lines in the way?
Old Aug 22, 2002 | 06:35 AM
zcivic91's Avatar
Default Re: MY hood wont close!! (HondaCRX)
it lines uup and is not hitting anything!
it only latches to the point where u just lift up the lever and can open it again..
it just wont lock.
i tried to loosen the flat head thing but its tooo tight..should i loosen the 12mm bolt the unscrew it some??
Old Aug 22, 2002 | 07:50 AM
Yes try to get that thing loose this will give you that extra lenght needed to make it latch completey. Try spraying WD-40 on it and let it soak and try lossening it.
Old Aug 22, 2002 | 08:28 AM
Mr Furball's Avatar
ok I had the same problem, On the hood the pointy latch that goes into the base can be adjusted. there should be a cut in the middle of the point and take a screwdriver and turn the point back and forth to make it longer or shorter which ever way to make it shut.
the point also has a spring on it so you can locate it better.
see what happens
Old Aug 22, 2002 | 11:44 AM
crxaddikt's Avatar
Default Re: MY hood wont close!! (FURBALL B-16)
whatever you do, if you cant get it to where the spring locks into the hole, just secure the hood down with bungees or something , cause i had my hood fly up on me just a week ago, and it shattered my front window, going 80, and it was freaky, but it was my fault, cause i switched from my bungee cords, to some rubbery strap, which was too flexible to hold it, and the wind caught it, and SMACK!
but my problem is that the spring (top peice) is about 1/2" off from the hole on the bottom, but if your hole lines up with the spring thing, just play around with the bottom or top latch pieces, by loosening and moving around, and re-tightening them until it fits.
Old Aug 22, 2002 | 11:47 AM
Steve Berman's Avatar
hood pins?
Old Aug 22, 2002 | 01:31 PM
zcivic91's Avatar
Default Re: MY hood wont close!! (Steve Berman)
ok i adjusted it..
Old Aug 22, 2002 | 02:55 PM
So I guess this fixed it???
Old Aug 22, 2002 | 03:28 PM
zcivic91's Avatar
yup
Old Aug 26, 2002 | 05:40 AM
YaY \ /
SlowDown
Apr 10, 2007 08:08 AM
initialvtec
Nov 9, 2004 07:19 PM
initialvtec
Nov 9, 2004 02:33 PM
GetCaughtDead
Oct 25, 2004 05:24 PM
7808
May 18, 2004 12:42 AM
