30A fuse in 7.5A spot (turn signals) Now they don't work
Old Jun 29, 2009 | 11:56 PM
Mishima's Avatar
Default 30A fuse in 7.5A spot (turn signals) Now they don't work
My turn signals died about a week ago on an Accord I bought about 3 months ago. First things first, of course, I checked the fuse. The fuse isn't blown, but not because there isn't a problem (I think) but because it's a 30 amp fuse in a 7.5 amp spot.
In this situation, what is likely to have burned out that now makes my turn signals non-existent?
Old Jun 30, 2009 | 12:29 AM
helldriver88's Avatar
Default Re: 30A fuse in 7.5A spot (turn signals) Now they don't work
try using the correct amperage replacement fuse. if problem still exists, could mean your flasher relay is fried.
Old Jun 30, 2009 | 04:12 AM
CheddarPopcorn's Avatar
New User
hey i have had problems with my turn signals in the fuse panel under the hood check the Backup (radio) fuse when i blew that fuse my turn signals would not work also check every fuse in the car Inside fuse panel and under the hood fuses only check the 7.5, 10, 15, 30amp fuses tho. and each fuse is labeled on the cover to the fuse panels
also im not sure where you are from but if you live near a future shop just go in there and ask them for a fuse and they will give you all the free fuses you could want i know personnaly i have gotten almost 100 different fuses from them in the past year because of me ****ing up **** when i wire it.
Old Jun 30, 2009 | 09:08 PM
Mishima's Avatar
Where is the flasher relay? And is there a different relay for the front/back?
Going to run through ALL of my fuses tomorrow.
kotton909
May 25, 2008 05:14 PM
pr0j3xt01v1c
Honda Civic (2001 - 2005)
Aug 10, 2007 06:34 AM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
ModlesSI
Feb 22, 2003 03:16 PM
AssPenny
Jan 7, 2002 09:29 AM
