Need help w/ compression
Old Jun 29, 2009 | 11:14 PM
RippSpeed's Avatar
Default Need help w/ compression
I'm not a math genius sooo I'm asking people in the know...
basically heres my situation. I'm doing a full 85mmx89mm LsVtec build. And I'm trying to figure out what compression will the motor ultimately be at...
Heres build plan.
Head:
-B18C1
-MaxFlow Ported w/ 1mm Oversize Intake Valves from CCCylinderHeads.com
-Supertech Springs
-Supertech Valves
-Supertech Retainers
-Supertech Bronze Valve guides
-Skunk 2 Pro 2's
-Combustion Chambers up to 85mm
-Victor X Manifold
-68mm Throttle body
-3mm RS 85mm Layer Head gasket
-ARP head studs
-High End header ( for now )
Block:
-B18A sleeved by JG punched out to 85mm bore
-Not milled just cleaned
-85mm 12.5:1 Mahle Piston
-Eagle ESP 137mm LS/B20 rods
-GSR Girdle
-89mm Crank knife edge and micro-polish
-Morso Oil pan
sooo I was told by CCCylinderHeads.com that by opening up the combustion chambers I should effectively lower compression by 0.5:1 compression. So will I be at 12:1 compression ??? PLease let me know, thanx
Old Jun 29, 2009 | 11:22 PM
Combustion Contraption's Avatar
Default Re: Need help w/ compression
Not necessarily.
You will be ordering a 12.5:1 piston from Mahle, but you need to remember that the advertised compression ratio is calculated with a certain stroke, piston to deck height and CC's. If they have a "12.5:1" piston with .030" piston to deck, and you put it in your block that has .020" piston to deck, you're gonna be staring at more than 12.5:1 compression.
I can open the chambers to match the bore, and depending on additional chamber work you can lose up to a full point in compression. The only way to be sure what compression you have is to CC a cylinder with the piston installed, and CC a combustion chamber and then do the math. Thats the only way to be 100% sure.
p.s. I just replied to your email.
Old Jun 29, 2009 | 11:27 PM
RippSpeed's Avatar
Originally Posted by Combustion Contraption
Not necessarily.
Steve your the ish man... Thats why I want you to be the only one to touch my head...
Problem is I already ordered the Mahle pistons and I cant just return them... I paid up the *** for them $510.00 because they dont make them in a 85mm size anymore...
Problem is I dont know where to go for to CC my motor ....
Old Jun 29, 2009 | 11:32 PM
You probably dont need to return them. Do you have a part number for the piston that you have? We can start by finding out exactly how they are calculating it as a 12.5:1 piston.
Old Jun 29, 2009 | 11:34 PM
RippSpeed's Avatar
part number# is ACR181346D06
Old Jun 29, 2009 | 11:46 PM
Got some bad news for ya.
That compression is measured with a 87.2mm stroke, so with a 89mm crank, you're looking at something in the 13:1 neighborhood, without any chamber mods. BUT again, the only way to really tell is to have everything CC'ed.
Old Jun 29, 2009 | 11:47 PM
RippSpeed's Avatar
but we are planning on doing chamber work though. by opening them up to 85mm right ...
Old Jun 29, 2009 | 11:49 PM
Right. But since I havent done the math, the compression could be higher than 13:1 before chamber work, thats why I said "13:1 neighborhood". Everything needs to be CC'ed, thats the reality, unless you want to get new pistons for some more breathing room.
Old Jun 30, 2009 | 12:08 AM
RippSpeed's Avatar
DAmm it!!! I talked to a tech guy at Mahle and he said it should be fine because I'm using a 137mm rod vs 137.9mm rod... I was using the zealwerks.com compression calculator. And it look like it would fall into 12.06:1 compression....
heres the numbers I imputted in:
bore: 85mm
stroke:89mm
deck height:211.84
combustion chamber:46cc ( I figured that since the B20 head has 45cc and I plan on having you open up my combustion chambers to 85mm sooo it should be 46cc right ???)
Dome: 6cc
comp height:30
rod lenght: 137mm
gasket layer:0.026
Old Jun 30, 2009 | 11:27 AM
The only way to be sure is to CC it, I'm sorry but I can't say it any other way.
Old Jun 30, 2009 | 07:11 PM
gstrudler's Avatar
What/where is the best place to get this done and approx cost?
Teamdiesel
30
Mar 25, 2009 05:39 AM
ticket_target
Nov 11, 2006 11:26 AM
Full Race A6
Sep 22, 2004 09:34 AM
Full Race A6
23
Jul 28, 2004 04:18 AM
NightHawkC5
Feb 23, 2003 09:02 PM
