Koni install
Old Aug 21, 2002 | 06:08 PM
tylerdurden's Avatar
Default Koni install
Looks like my suspension is finally going in this weekend and I have a couple questions (I'm sure there will be more later). First, on the front shocks there is supposedly an "index mark" to align the shock's rotation. Is the index mark the smooth indentation near the bottom of the shock? Does it matter where the spring and spring perch are rotated to? Also, what is a good adjustment for Yellows to start out with? I've heard a half turn is a good start. Thanks in advance.
Old Aug 21, 2002 | 06:12 PM
Owhite3's Avatar
Default Re: Koni install (tylerdurden)
Do I assume these are the ones you have to take off the car to adjust?
Old Aug 21, 2002 | 07:01 PM
Default Re: Koni install (Owhite3)
No these are Yellows, not Reds, should have been more specific.
Old Aug 22, 2002 | 05:00 AM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
The yellow ie. Sports come two ways. One is take off the car, compress and turn to adjust. The other has a **** you put on the top and turn to adjust
Old Aug 22, 2002 | 05:26 AM
keithv's Avatar
yes that is the mark to align the shock and the fork.
the spring perch doesn't matter, but the hat that goes on top of the spring does. you need to have that aligned properly so it will slip into the two holes in the chassis and have the fork bolt line up. if you are using lowering springs, the alignment isn't a problem (usually) as the spring is not under tension and the hat can move freely.
the 8040 series is the kind that you have to take the shocks off the car, compress and turn to adjust.
the 8041 series have the **** at the top of the shock piston that you turn to adjust.
Old Aug 22, 2002 | 08:11 AM
Default Re: Koni install (breaka_1_9)
Thanks a lot for the info, guys. Does anyone have a good starting adjustment, though? Also, since the spring won't be under tension, what is the best way to lower the car onto the spring? Is there any chance the spring won't line up with the hat on top (since it will be loose)?
Old Aug 22, 2002 | 09:12 AM
keithv's Avatar
start at full soft and work your way up from there till you find an adjustment you like. you will need to experiment to find the setting that you like.
the spring will stay pretty centered since it sits in the perch. althouh, i have had the spring pop back into place a few times once things settled.
if you have two people, lower the car slowly and have the other person make sure the springs are seating right.
or
you can zip tie the top hat to the spring to make it seat properly.
Old Aug 22, 2002 | 11:38 AM
Thanks a lot breaka. It's nice to find someone who knows what they're talking about AND is willing to share. We'll see how it goes.
Old Aug 22, 2002 | 01:42 PM
shortyz's Avatar
yeah hes right. but make sure u lower the jack slower so you dont cut your friends arms off!
Old Aug 22, 2002 | 04:45 PM
Crxer's Avatar
im running full hard in the front and one full turn less than the hardest in the rear on my crx. thats my favorite setting so far. if you go full the ride feels really tight but horrible...
vteec
May 14, 2004 01:05 AM
DR.DRum
Apr 22, 2003 01:37 AM
Shoe
May 22, 2002 06:07 AM
reVVin
Mar 19, 2002 05:51 PM
shpae
Dec 17, 2001 10:18 PM
