Testing the waters: GSR Swap
Thinking about selling my usdm 1.8 gsr swap. It was completely rebuilt with stock oem parts. Has 0 miles on the motor. Taking offers.. Low ballers dont bother!!! Comes with everything minus ecu and axles.
Only have pixs of the head as of now....
Text me @ 954.383.0193
-new oil pump
-new water pump
-new timing belt
-new real main seal
-new oil seals
-new piston rings
-new rod bearings
-block was honed
-new i & e valves
-new valve seats
-new stem seals
-new valve springs
-new retainers
-new dizzy o-ring
-new camshaft seals
-new camshaft plug
-new i mani gasket
-new head gasket
-new oil pan gasket
-new valve cover gasket set
Photos:
-new oil pump
-new water pump
-new timing belt
-new real main seal
-new oil seals
-new piston rings
-new rod bearings
-block was honed
-new i & e valves
-new valve seats
-new stem seals
-new valve springs
-new retainers
-new dizzy o-ring
-new camshaft seals
-new camshaft plug
-new i mani gasket
-new head gasket
-new oil pan gasket
Photos:
