91 crx si (zc)
ok here we go with another question what would i look up valve cover gasket, and valve lash spec. for, and is this motor vtech? and thanks 4 all the help with the timing belt info guys
I think you have to get a valve cover gasket from a 1st Gen Teg (87 or so) if it's the DOHC ZC(but dont quote me on that). If it's the SOHC ZC then just get it for a CRX Si. Neither of the engines i just stated have V-Tec.
valve cover gasket is 88-89 Integra D16A1
DOHC ZC valve lash:
Intake - 0.13-0.17mm or 0.005-0.007in.
Exhaust - 0.15-0.199mm or 0.006-0.008in.
valve lash is checked between the top of the rocker arm and the camshaft lobe, not between rocker and valve stem
DOHC ZC valve lash:
_Cyclone_
Jun 25, 2005 11:04 PM
Creepshow S60
Nov 26, 2002 12:45 PM
