View Poll Results: which one?
ls-vtec w/ ls tranny
14
28.57%
b18c1 and tranny
35
71.43%
Voters: 49. You may not vote on this poll
ls-vtec vs b18c1
Old Jun 28, 2009 | 10:53 PM
notsoslow's Avatar
Default ls-vtec vs b18c1
stock for stock, what would you prefer...
ls-vtec w/ ls tranny or complete b18c1 and tranny?
Old Jun 29, 2009 | 01:32 AM
92civiceg9gsr's Avatar
Default Re: ls-vtec vs b18c1
The GSR just because of the better transmission.
Old Jun 29, 2009 | 10:29 AM
FST GSR 1's Avatar
This is like comparing a bicycle to walking...
Old Jun 29, 2009 | 11:01 AM
hmoobhero's Avatar
tru.
can you explain more? which one is the bicycle? walking?
if the ls/vtec was built correctly it is stronger than the gsr. but then again the tranny plays a big role also. if both motor used the same tranny then the ls/vtec would be the better choice, given that it was build correctly...
Old Jun 29, 2009 | 12:43 PM
nels00n's Avatar
+1
gsr bicycle ls-v walking
Old Jun 29, 2009 | 12:46 PM
American.Graffiti's Avatar
GSR +1
Old Jun 29, 2009 | 02:35 PM
killerpenguin21's Avatar
why an ls/v with ls trans? cant oyuouy just get a better trans? or atleast a 4.7 fd?
Old Jun 29, 2009 | 03:00 PM
EgCivicSiHatch's Avatar
I had an LS/vtec[174hp to the wheels] on a b16 tanny with a 6 puck and phantom grip....and it was MEAN!
...but bad for road trips.....I blew the motor and I am building a new one in hopes of putting 200+ to the ground.
Short gears FTW!
Old Jun 29, 2009 | 03:12 PM
vanny_david's Avatar
I will vote LS-VTEC if you have a better gearing tranny other than LS...
Old Jun 29, 2009 | 03:18 PM
MKTurismo's Avatar
Yea bra, everyones going to give you the same answer its that silly of a question.
On the other hand, like hmoobhero said if its a LS/V with with a few common internal upgrades I'd pic LS anyday.
+1
Old Jun 30, 2009 | 04:47 AM
notsoslow's Avatar
i drive an ls and was thinking of going vtec but i summed up the cost and its going to cost just as much as a full gsr and tranny swap i can get from a local shop. i just wanted some input and votes on whats best for the money and it seems that i was pretty right on behalf of the gsr swap having more votes. thanks guys, i appreciate it
Old Jun 30, 2009 | 05:11 AM
99JDMHATCH's Avatar
yea go with a gsr over a LS vtec simple because better cams, better tranny, and by the time you buy to have a LS vtec put together it'll cost more.
Old Jun 30, 2009 | 01:18 PM
MKTurismo's Avatar
^Well prices vary so much it kinda depends.
My setup on the drawing board right now for my road racing LS/V is only $2100, built and machined.
Thats not including the gearbox but I can have one pulled locally for only $300. Its all about who you know and where you shop at.
Old Jun 30, 2009 | 02:06 PM
muneeb's Avatar
b18c1 ! no questions asked
Old Jun 30, 2009 | 02:12 PM
092eg6's Avatar
b18c1 ftw, better design bottom end, handles more abuse.
Old Jul 2, 2009 | 07:28 AM
notsoslow's Avatar
61" Samsung LED TV= Honda-tech, Facebook, and CSS from my bed
bought this instead
Old Jul 2, 2009 | 11:28 AM
It's all in the build not the design. The whole r/s ratio argument was thrown out the window years ago
My home built lsv is going on like 2 years and 3k miles with a 9100 rev limit and 203whp now. And you better believe it sees 9k multiple times everytime I drive it. First motor I ever assembled to boot.
Old Jul 2, 2009 | 01:36 PM
DC_Legacy's Avatar
Same here, first automotive motor I've assembled too. Looking back on it its been a little over a year since it was assembled and have about ~2K miles on it + running sound on the daily grind everyday.
Old Jul 2, 2009 | 01:55 PM
evertp1's Avatar
+1 GSR for higher compression and better transmission
the ls/vtec also depends on which VTEC head as they all have different cams.
Plus youll ger more respect for being able to afford a GSR rather than putting together a LS VTEC
Old Jul 2, 2009 | 02:18 PM
DC_Legacy's Avatar
Really? My hats off to anyone who can do a build/rebuild LS VTEC or not, rather then just performing a simple swap which can be afforded by anyone who can save a little money or with other monitary assistance.
Old Jul 2, 2009 | 02:54 PM
DA3's Avatar
DA3
Originally Posted by DC_Legacy
Really? My hats off to anyone who can do a build/rebuild LS VTEC or not, rather then just performing a simply swap which can be afforded by anyone who can save a little money or with other monitary assistance.
i agree it takes alot more knowledge and understanding to put together a reliable ls/v i have one sitting right next to box in the shop im at, you need to know what to use so it wont be over kill or underkill. as for the trans it depends on what your reference is drag, street, strip. i suggest b16 for drag as it has shorter gearing better for accel, ls for street gotta need that long fifth for nice pulls on high ways or so
Old Jul 2, 2009 | 04:42 PM
Garage 808 Hatch's Avatar
Heres where you go wrong. your poll says Stock vs Stock. then you bring up the **** about a built LS-V. thats not stock. and an LS-V is not "stock" either. therefore your entire thread is off base. The LS trans is a shitty gear ratio for NA. I'd rather have a complete B16A swap than a 1.8 with an LS trans.
And a built GSR will be stronger than a built LS due to the stock integrated crank girdle, and the block has more webbing. IMO.
Old Jul 2, 2009 | 05:30 PM
EgDreams85's Avatar
GS-R
Old Jul 2, 2009 | 06:27 PM
LsV9kEz's Avatar
I built an lsv use it daily, sees 8k daily, a lot of fun and has about 13k plus miles
Old Jul 2, 2009 | 06:45 PM
UncleD's Avatar
Exactly what came to mind for me.
