LS Swap in 95eg??
Im stumped!! Im dropping a LS swap in my 95eg and the rear mount and rear mounting bracket are 2 inches away from being lined up together. I have the left and right mount in perfectly fine, it's just the rear mount causing me trouble.
What am I missing here?
Thanks
Thanks
You are using the right mounts correct?(IE:The metal L bracket,etc?)
Some people use a combination of D and B-series mounts when they swap in a B. I however bought new mounts that were for placing a B-series engine into an EG engine bay. You have to use the Integra Rear L bracket as well. I don't like the stock mounts as they allow the engine to move quite alot..I got stiffer mounts when I put my LS in my EG.
That's not the right mount you have.. the one that Honda gave you is for an Si.. you need to take it back and get it exchanged for the Integra one.. The Si mounts are about 2" shorter than the Integra mount... I had that same problem when I first put my b16 in my EG..
Moonraker09
13
May 14, 2011 11:55 AM
