car continues to blow white smoke after a new head gasket has been eput in
Old Jun 28, 2009 | 11:30 AM
honda luv's Avatar
Default car continues to blow white smoke after a new head gasket has been eput in
hey,i just put a new 3 layer metal head gasket in my 91 LS and she is still blowing white smoke. I torqued everything down to factory specs and it is on time,but it's still blowing smoke,any idea why it would do this?and also,before i did the head gasket every time i got on it more than just normal driving i could smell rich fuel,my fuel pressure is still at 34 pounds.if anyone has any suggestions or tips/info p[lease let me know.thanks.
Old Jun 28, 2009 | 01:09 PM
Ruben19's Avatar
Default Re: car continues to blow white smoke after a new head gasket has been eput in
did you inspect the heads for cracks.
did you take the head to the shop?
Old Jun 28, 2009 | 06:39 PM
J.WOLFE~v1.0's Avatar
did u by any chance try ignition fluid?? if not that then im not sure man gl
Old Jun 28, 2009 | 10:23 PM
rallyrat427's Avatar
you didnt get it milled. did you?
Stasher1's Avatar
piston rings would be my first thing to check
do a compression test
or a leak down test
Old Jun 28, 2009 | 10:35 PM
xrated1's Avatar
iam with rally rat,,,should have gotten the head check for straightness with a straight edge,,,,just take it too your local machine shop and have them check it and its free no charge to see if it has been warped.
Old Jun 29, 2009 | 12:50 PM
honda luv's Avatar
yeah i checked for cracks in the head before i put it back on.the car just barely is about to roll 130k miles and has only overheated once before,cuz of low coolant fluid but i got it before it had reached max temp,was just over the mid level on the guage before i got to a spot where i could stop and put water in it.
Old Jun 29, 2009 | 12:58 PM
honda luv's Avatar
what should my comp. be at in a 91 LS motor,not sure if it would effect it but only things done to it is 2 1/2 inch header back exhaust,adjustable cam gears 3 degrees retarded and a 3 layer metal head gasket.
Old Jun 29, 2009 | 03:37 PM
its probably warped and it will only get worse the more you run it
youll need to do the headgasket all over again (with a new gasket), only this time you will need to take the head to a machine shop.
ive been in your shoes before. sucks when you cut corners and it comes back to bite you in the ***
Old Jun 29, 2009 | 03:40 PM
or a leak down test
why would you check these if you have WHITE smoke??
white smoke = coolant
blue smoke = oil
Old Jun 29, 2009 | 03:45 PM
KILLAB17VTEC's Avatar
Genetically Gay
yeah..mine blow some black water dust outta exhaust pipe.
Old Jun 29, 2009 | 03:59 PM
94 ls-r's Avatar
Sound like the head is warped. You will have to have it machined smooth again. Also wanna check the block. It can warp too
Old Jun 29, 2009 | 09:13 PM
joeg_713's Avatar
get head machined or rebuilt....
Old Jun 30, 2009 | 12:54 AM
Ruben19's Avatar
blue smoke = oil
he's right.
coolant is getting inside the combustion chamber.
Old Jun 30, 2009 | 12:05 PM
honda luv's Avatar
yeah i started checking comp on it and comp in first cyl. was showing just under 100,so i just stoped right there guessing that my head is warped.thanks all,anyone know of a good machine shop in new hampshire,prefferably around the lakes region area,thats decently priced?
benjamin
Jul 2, 2022 11:49 AM
lifesastruggle
Engine Management and Tuning
Feb 15, 2017 03:22 AM
keljohns992
Honda Civic (2001 - 2005)
Dec 14, 2013 04:25 AM
zcmotor
May 29, 2008 07:04 PM
4drITR
Jun 4, 2006 12:31 PM
