auto-manual trans swap questions
So he spelled VTEC wrong. Who cares!
Now that that's out of the way...
It's not very difficult even for a novice. You will need many parts, and some of them are easiest to install with the engine removed. Research and do it, it's worth it.
what would i need to change on my engine? can you juss pull the eng and trans and put it all in?? would the harrness all plug in? i would want to keep my engine.
tranny, clutch, linkages, shifter, cluth pedal, clutch master cylinder, slave cylinder and ur hydro line
i know on a eg/delsol hasport makes a mout that you need with the swap but idk abut the ek
find a single cam tranny take urs off put a clutch and flywheel on the motor bolt up ur 5sp trany unbolt the block off plate for the pedal install pedal and master cylinder/resivor put motor and tranny back in the car hook up linkages and role out
civiclxb16a
Jul 18, 2006 06:50 AM
speedxassassinx
Feb 17, 2004 12:47 PM
SpoonSportsJunkie
Oct 28, 2002 04:33 PM
