1st project build
I’m in need of some assistance. I’m going to school to become a master mechanic and while there I plan to use my car (91 5spd Integra GS) as my project car. The car already has modifications that include tokico adjustable coilovers, stage 2 clutch, short throw shifter, rear sway bar, cat-back exhaust, and summit slotted rotors and ceramic pads. I’m still in the process of finding out what brand parts I have in the car, because I bought it with most of the parts already installed and I want to make sure that the next parts I put in work well with what I already have. I’m looking to achieve anywhere from 400-500 hp from the vehicle when I complete it. I was thinking about going with an 88-91 B16A and rebuilding it with a forged rotating assembly along with a stage 2 top end and possibly run 30 psi of boost. A few people have told me to do an ls/vtec conversion, while others have told me to just build up my B181A1 and run it under 30 psi of boost. My school gives the students a pretty sweet discount on parts from both Summit and Napa, so I have room in my budget to “play” a little. What are you guys’ opinions as to what would be the best route as far as the build or what parts to use? I know that I will have to further reinforce the body so it can handle the strain of the higher horsepower along with the drive train. Please give me your thoughts because this will be the first car that I completely upgrade I could really use the help of seasoned techs.
Hahahahaha... lmfao about vtec not being all that its hyped... i used to have a dyno comparing a setup that was B18b built and made 237hp and the only thing that was changed was a vtec head was put on and the engine went up to 351hp. All the extra power was from 5500rpm up till 8000, so clearly vtec makes a hell of a power gain and works with turbo like butter does with toast (it makes **** better.)
But for 400hp a fully built B18b/a will be nice and fun to drive, but for anything more its going to be easier to make the extra power with vtec. Goodluck with your project over the years..
I figured as much. I haven't seen too many non vtecs with more than 300 hp tops. If using a vtec will make it easier to build the power that I want, I know which direction to go in.
As far as the burn-out comment goes, vtec engine make most of their power and tq above 5500, so if you're looking for straight off the light power then you need to add components that lower your power band. This is especially true if you turbo. I LOVE vtec with turbo because if you tune it right you'll get your spool and then vtec will kick in, and it's like having two engines under your hood.
30lbs sounds like quite a bit for boost, what kind of power numbers are you looking for?
I had a civic with a d series motor in it and i know what they are capable of. I also know that a high amount of torque is worthless unless you have some substantial amounts of hp to back it up. Even though this is my first project car, I've been building motors cars for quite some time (primarily US domestics with V8s) and I know that torque only gives you a good takeoff and accelleration, not high top end speeds. This project car is meant to rival the power of the V8s that I have built in the past, not give me a good holeshot on the strip.
Obviously your not that intelligent since you didn't know HP is dependent on torque Horsepower = (Torque x RPM) / 5252 here's an equation that proves the relationship between hp and torque so why don't you learn nooob.
Read up about engines and find out what the best and d series suck until vtec or boost and a b16 vs b18b1 the b18b1 will own turbo. And my turbo teg ill do 150mph but when do i hit that on a normal day. If you go to the street races the max you hit is in a 1/4 mile so i dont know what your planning on doing
Wow. Talk about a confusing thread with tons of broken english and misinformation. You can get 400-500 hp out of almost any honda motor if your budget is big enough. Decide on your budget and go from there.
If you're absolutely set on building the DA and if it's the only car that you drive, a vtec head on your stock block + a turbo kit is going to be your best bet. Best combo to minimize downtime, maximize hp, and minimize cost. If you can afford it, consider starting with a dc/eg/ek rather than the DA unless the DA is super clean.
If you were to ACTUALLY read my comment, you would notice that I correctly relate them without having to show off my mental prowess and state such a rudimentary (but fundamental nonetheless) equation. Also, like a member mentioned earlier, "post number doesn't = knowledge".
Okay that's great you made 100hp more by slapping on a Vtec head but if you ported the ls head it would flow way better also. I don't know about you but I like making power from 3k to about 7k. Not have to tach my car up to 5500 to get power lmao. And what was the torque difference from the head swap, all your about is high hp numbers, When what really matters is the torque curve and amount of torque, thats what makes driving fun
I've driven hondas with vtecs in them and none of them have ever burned out in second (let alone first) gear like my integra does now.
