Beginner question on d16y8
Okay, so im pretty much new to the whole JDM thing. and i have a d16y8. How do i know if it has VTEC? Is it sopposed to say it somewhere on the block or what? I was told that all d16y8's have VTEC. Is that true? I have a EJ8 so yeah. Its automatic "sigh". Help please. New to all of this!
D16Y8
VTEC
Also available in New Zealand under the code D16Y6
Found in
1999-2000 Honda Civic SE 1.6 Vtec (UK)
1996-1999 Honda Civic EX Sedan
1996-1999 Honda Civic EX Coupe
1996-2000 Honda Civic EX (US)
1996-2000 Honda Civic SI (Canada Only)
1997-2000 Acura 1.6EL (Canada Only)
1996-1997 Honda del Sol Si
1997-2000 Rover 416 Auto
Displacemnt : 1590cc
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Rod Length : 137 MM
Rod/Stroke : 1.52
Compression : 9.6:1
Valvetrain : SOHC 4 valves per cylinder
Power : 127 hp (94.7 kW, 229 ps) @ rpm
Torque : 111 ft·lbf (45.79 kg/m, 145.1 Nm) @ rp
Head Code : P2J
Piston Code : P2P
Redline 7200 rpm
ECU Code : P2P
VTEC
Found in
Rod Length : 137 MM
Rod/Stroke : 1.52
Compression : 9.6:1
Head Code : P2J
Piston Code : P2P
Redline 7200 rpm
ECU Code : P2P
lindsix3
41
May 27, 2010 09:42 AM
hxtasy
May 11, 2007 10:28 AM
