5th gen license plate relocation
Old Jun 28, 2009 | 06:56 AM
19Accord97's Avatar
Default 5th gen license plate relocation
Hey Guys,
My car is getting painted and I want to move the front license plate from the middle to the drivers side turn signal, well right below that. What all do I need to mount it? I dont have my car and can't find any pics of it w/o the bumper off so I was hoping to get all the stuff before I get it back which will be later today. IL cops are super strict around my area about front license plates.
Thanks
Old Jun 28, 2009 | 09:26 AM
tamadrummer1120's Avatar
Default Re: 5th gen license plate relocation
Here is one relocation possibility for you.
Before:
Bracket Mock-Up:
Initial Mounting:
And with the new lip:
Here is the complete album with all the pictures of the fab work if you want to see more:
http://s5.photobucket.com/albums/y16...nda/?start=all
Message me if you need anymore information.
Good luck!
Old Jun 28, 2009 | 09:48 AM
19Accord97's Avatar
Not bad! But I dont want to block of too much of the cooling capability.
Thanks for the suggestion, though!
Old Jun 28, 2009 | 10:29 AM
actually, it can help direct the air up the radiator and condenser. But just a suggestion.
Old Jun 29, 2009 | 03:24 AM
01SlvrA-cord's Avatar
Google search "JDM License plate relocator" you can buy several different types online. Ebay has one for $20.00, or you can pay up to $50.00 at any "jdm" warehouse. I bought the ebay one several weeks back. I had to modify it slightly but it worked out great on my 6th gen. Its a really clean look, doesn't look like you just hacked your bumper.
Old Jun 29, 2009 | 08:31 AM
BBallz24's Avatar
I made one for about $5 or so. I'll find the link & pics.
Originally Posted by BBallz24
Here are some pictures of the brackets I made. It was raining all day so I didn't get a chance to fit them in. I'll figure out the plate fitment and everything as well. Trying to utilize the 2 bolts holding the lip on. More pics tomorrow if no rain.
THE 5 1/4" SHOULD BE 5 3/4"
Making sure there is enough metal to frame around the plate. I'll test fit and install tomorrow if no rain.
With plate
With holder
Rivets and rivet tool to hold metal together
Ok, I just put one crossbar at the bottom of the "arms". This thing is pretty solid as is and I thought any more would just be overkill and waste my time. I put 4 rivets in each side to connect the crossbar to the "arms". I took a screwdriver through the hole in the lip and pressed up to make a mark in the aluminum. I then drilled holes on those marks which would then let me utilize the holes from the lip and thus making this removable and not permanent. I don't plan on moving the plate, but I figure why make new holes when I can use ones that are already there. You can attach the license plate to the bracket before or after installing the bracket. Really makes no difference at all.
1. Remove your passenger side bumper lense.
2. Feel inside the hole with your hand, where the bumper connects to the lip. These are the 2 bolts you can see and feel through the hole.
3. Fit the plate holder through the bumper light hole and line up the holes in the metal with the holes in the bumper to connect the lip.
4. Place bolts through hole with washer above bracket, then under lip, and attach nut.
5. Tighten bolts firmly.
6. Re-install bumper lense.
7. Enjoy!
Here are some pictures of it with and without the plate. I did redrill one hole to make it closer to the bumper. This is prior to redrilling.
From under the car
No light
No plate
Finished
Last edited by BBallz24; Jul 30, 2009 at 10:16 AM. Reason: Pictures were moved, links were bad. Updated with new pictures.
Old Jun 29, 2009 | 11:46 AM
BBallz, i like how you did yours. Did a very professional job. Awesome!!
Old Jun 29, 2009 | 02:33 PM
BBallz24's Avatar
Thanks. Got the idea from a guy on Gen5 and changed it a little. I drilled/made no extra holes. I used 2 holes on the bottom of the bumper where the lip mounts to. That way it's nothing permanent and no holes if you take it off. Doesn't interfere with turn signal either. I think I'm going to add some bolts to the bottom of it though. I'm thinking Gorilla Glue 2 nuts to the back of the plate frame and secure it from the back. If I do I'll add pictures as well.
Old Jun 29, 2009 | 08:15 PM
19Accord97's Avatar
Nice! Right now it is ziptied....lol!
Looks like i'll be copying you after I get my paintjob paid off!
Old Jun 30, 2009 | 06:42 AM
Here are some photos of my 6th gen license plate bracket. Its a 1 piece braket off ebay.
Old Jun 30, 2009 | 11:25 AM
Not a big fan of cutting the actual license plate, but good fab.
Props for living in MD!!!! haha
Old Jun 30, 2009 | 11:37 AM
I bent it under and flattened it because I initially had it mounted flush in the center of the grille, I just need to dedicate a entire day to standing in line at the MVA and waiting for a new one.
Old Jun 30, 2009 | 11:41 AM
Oh ok. No I feel ya on the MVA day.
Talk about a waste.
B16marley
Mar 11, 2011 10:32 AM
silvervtec
Oct 18, 2009 08:35 PM
98vtec
Nov 10, 2007 10:28 PM
themurrell
Aug 10, 2007 05:09 AM
Thirty-Nine
Aug 13, 2004 03:56 PM
