toda b's
Old Jun 27, 2009 | 10:14 PM
baysic r's Avatar
Default toda b's
i got a set of toda b's and was running them on crower dual springs with retainers. for maybe 2 months and i ended up cracking my block my port n polish gsr head is gone.
i was wondering if the toda's are to big for the crower valve springs cause i had 3 innner springs snap and all but 2 valves were either bent or broken. now it could of been like a chain reaction but i'll never know. and should i just spend the cash and get the dual valve
spring set up from toda for the toda cams?
Old Jun 28, 2009 | 11:18 PM
mugen mj5's Avatar
From: Where the shooting range is on the streets of LA, CA.
Default Re: toda b's
i like to know this as well... up
Old Jun 29, 2009 | 04:01 AM
95DC2GS-R's Avatar
The Toda Spec B is a pretty lofty cam.. What springs and retainers were you using? There's more than one..
Old Jun 29, 2009 | 08:33 AM
Mashimaro's Avatar
i decided to run Toda springs and Toda retainers with my B's. valve lash is set to Toda specs and they're noisy as hell on cold start. so far, no problems at all in the past year. no abnormal wear and my rockers look great still.
you can't go wrong using matching springs for the camshaft (other than the cost).
Old Jun 29, 2009 | 11:49 PM
b19coupe's Avatar
Toda B's are not that big. You might want to have a professional diagnose the cause of the valve spring failure before you invest in a new motor-valve springs, etc.
KingOfQB
Jan 26, 2006 08:04 PM
JDM97dc2R
Dec 29, 2005 09:15 AM
Slow96RedEk
Jan 15, 2004 04:43 PM
MugenB16A2
Dec 2, 2003 12:37 PM
