FS A ton of CRX parts from a 88 B16A CRX SI
I had my CRX parked in my hometown, and while I was gone it was vandalized. A bunch of parts were stolen. I am looking to part out the rest of it and get it gone.
Below is a list of parts.
No reasonable offers will be refused.
Thanks!
Engine JDM B16 w/labor 2000 Only the bottom end
OO Integra Type R Valve Train 150 STOLEN
Distributor OBDO 125 STOLEN
Skunk2 Intake Manifold 550 STOLEN
BBK JG THROTTLE BODY (70mm) 300 STOLEN
Chiped PW0 ECU 200
PR3 ECU 150
K&N Cold Air Intake 120 STOLEN
STR Cam Gears 175 B&M STOLEN
Fuel pressure regulator & Gauge 75
New B16 Timing belt 50 CUT
Water pump 50
TOTAL ENGINE 3945
Drivetrain JDM YS1 Tranny with Factory LSD 400
New Hubs with extended studs 160
New Wheel Bearings 240
Exedy Organix Clutch 200
15" Rota Subzero Wheels 600
15" Sumitomo Tires 350
TOTAL DRIVETRAIN 1950
Suspension Tokico HP Blue's Shocks 250
Neuspeed Sports CoilOver Springs drop 2.0" front/1.8" rear 130
Poly Bushings with Zerk Fittings 45
Inner/Outer Tie Rods BallJoints and Control arm Bushings 150
Steering Rack 50
1990 Integra Rear Disk Brakes 200
Integra 40/40 Brake proportioning valve 30
FastBrakes.com Integra Callipers 185
FastBrakes.com 11" front brake kit 250
Goodridge Stainless Steel Brake Lines 75
New Rotors 80
ATE Super Brake Fluid 15
TOTAL SUSPENSION 1460
Interior Tenzo Type R Drivers Seat 250
Oil Temp Gauge 10
Autopower bolt in 4 point roll bar 600
TOTAL INTERIOR 860
Exhaust Greddy SP Cat Back Exaust with resonated test pipe 400
TOTAL EXHAUST 400
SIR Spoiler 150
Viper Keyless Entry and Alarm 150
Hasport Short Shifter 50
Hasport Shift Linkage 120
Hasport Motor Mounts 300
TOTAL OTHER 770
Thanks!
Chiped PW0 ECU 200
PR3 ECU 150
Water pump 50
TOTAL ENGINE 3945
Steering Rack 50
New Rotors 80
Oil Temp Gauge 10
TOTAL INTERIOR 860
TOTAL EXHAUST 400
SIR Spoiler 150
TOTAL OTHER 770
