DC header for EK/EG fitment on EF
Old Jun 27, 2009 | 11:02 AM
Wilky's Avatar
Default DC header for EK/EG fitment on EF
I have a dc 4-2-1, 1-piece ceramic header for a 92-99 civic.
Can I bolt up this piece up without moving my front subframe (stock)? Anybody done it?
Old Jun 27, 2009 | 11:09 AM
k20rex's Avatar
Default Re: DC header for EK/EG fitment on EF
i took a ls-vtec out of my 96 hatch and put it in my crx and it had a dc 4-1, i had no problems
Old Jun 27, 2009 | 11:42 AM
GreedyPT's Avatar
The 4-2-1 doesnt present any problem apart from only having one O2 bung (troublesome if you are using a OBD0 ECU).
Old Jun 27, 2009 | 12:24 PM
Wilky's Avatar
That's comforting, but I am pretty sure my DC header has a lone 02 bung at the same location as the stock manifold in my 90 Si.
BTW: I thought that only OBD2 cars used two 02 sensors...
Old Jun 28, 2009 | 07:24 AM
Wilky's Avatar
Anybody actually done this?
Old Jun 28, 2009 | 09:22 AM
Radim's Avatar
If it's a SOHC D-Series it should fit, as long as you cover up that O2 bung near the cat if it does have two bungs.
Old Jun 28, 2009 | 06:07 PM
Wilky's Avatar
Well, I answered my own question. You can't get it on without dropping the front subframe. I tried earlier today after removing the stock manifold, and no dice.
As I said earlier... I know it will bolt up. The problem is that you can't get it into position without actually removing the front subframe to make space for it (due to it being one piece).
4g4dcruisin
Oct 12, 2009 08:56 AM
Silver_Rex
Jan 15, 2004 03:35 PM
AlphaQup
Oct 28, 2003 03:53 PM
NorCalHB
21
May 19, 2003 07:21 AM
FreeMyndz v.FP
11
Jan 22, 2002 12:52 PM
