FS red 99 civic HB B20b ORLANDO
Old Jun 27, 2009 | 09:25 AM
formby's Avatar
Default FS red 99 civic HB B20b ORLANDO
1999 Civic 3Dr DX,122.5k on platform.
clean title.
i am the second owner, my wifes brother bought it new.
ORLANDO FL 32837
$6.5k OBO
Body/ Platform
OEM paint shines no cracks but needs a good clay bar. dent on rear hatch, two dents on hood and hood is slightly bent. black OEM style head lights, stock body other than that. NO RUST normal wear
has 1st gen gsr rims with 215-60-14 Michelin pilot tires. 80% left
ARP extended lugs on front hubs changed at tire kingdom
Stock suspension/ brakes
Brand new Brake job new blank rotors, best pads advance sells, drums and shoes with new hardware and rear solenoids. work done at coltires in orlando. under 1k miles ago
Windows were tinted a year ago and all the windows are legal tint. however, the windshield is also tinted with the lightest tint available.
Blue Interior is stock other than an ex cluster with my original center and a new cd mp3 ipod/aux connect radio. no tears on seats front or rear and is kept clean. normal wear
Air conditioning is on and runs great, No power Steering.
Has a stealth installed viper alarm system with hood switch, kill switches, back up battery, lift sensor, and a pizzo siren in the inside. installed at best buy along with radio.
engine management
OBD1 P28
b20b chip from phearable.net. no O2 sensors. uses 87 octane
Engine/Drive train:
Internally stock never opened 1996 CRV DOHC engine b20b with unknown mileage does not smoke runs great purchased 5-11-09 through jdmenginezone in NJ 126Hp 131Trq 8.8 Compression, has SI harness, 68mm bored obd1 LS intake manifold and 68mm Professional Products throttle body, 255 in tank walbro fuel pump, b16 crank pulley. billet cam cap, under 1k miles at this point vtec water & oil pumps, gsr timing belt and new rear main seal.
Focuz 4-1 header with flex pipe and Vclamp welded on. Crush bent 2.5" exhaust with matching Vclamp to header, 24" resonator, 26" round magnaflow muffler and oval magnaflow at the end. no rasp sounds great. last muffler painted black installed by road runner muffler in kissimmee
gsr transmission, new bearings/seals installed by honda, no grinds.already had a Quaife LSD installed when i bought it.
competition 6puck sprung clutch with stage 2 exedy pressure plate, oem type R flywheel.has around 3k on unit.
Gator stage 2 axles with fresh boots from gator. i went myself and had them inspect and refresh the axles.
all stock motor/transmission mounts have been filled with polyurethane except the oem jelly filled unit on timing belt side.
the bad: driver side window needs a new manual regulator. i already have new OEM weather stripping for the door. the center radio console does not sit flush with dash. window washer reservoir has a leak. dents mentioned above. one cap on dash is broken.
i love this car and need to sell it because my son and wife need more room.
i will be putting up pics when i borrow a camera. my wife broke mine...
pm me / email me formby46@hotmail.com
Old Jun 27, 2009 | 06:31 PM
DominicanDaddy69's Avatar
Default Re: FS red 99 civic HB B20b ORLANDO
please post some pics ?
Old Jun 28, 2009 | 05:34 AM
formby's Avatar
as i stated in the last part of the first post i am waiting for my wife to borrow a camera.
i have this pic
shows the color and tint when i get more ill take this one down and post smaller more detailed ones....
epolanco_ek4
Mar 21, 2013 09:01 PM
90daXsi
Mar 20, 2009 08:19 PM
TRAY
Dec 1, 2005 01:45 PM
TRAY
Nov 30, 2005 07:01 AM
