ls build
im in the process of building an ls and i have stage 3 crower cams full supertech valve train and i was kinda wondering how high of compression i should go i want to drive it almost every day but still be reliable let me kno what u think
91 lude blown up
90 crx ls
89 accord sold
91 lude blown up
90 crx ls
89 accord sold
91 lude blown up
90 crx ls
89 accord sold
91 lude blown up
90 crx ls
89 accord sold
Depends. With stage 3 cams your dynamic compression ratio will effectively raise your static compression ration quite a bit so you should be able to go quite high. If your pistons and combustion chambers are in great shape you could do as hi as 13:1 (with incredible tuning). If you are a mortal like the many of us on HT with less then perfect motors and perfect tuning I suggest going no higher than 11.5:1.
Have a look at PGMFI.org for lots of good info on how to tune it safely.
