Lighting HID/Xenon kits, Retrofits and Associated Topics
HID retro in JDM non-HID headlight
Old Jun 26, 2009 | 07:50 PM
6shootahorsenamedtrigga's Avatar
Default HID retro in JDM non-HID headlight
I going to do the front jdm conversion (DC2) and i have decided to buy the parts individually. To cut the story short I am doing an HID retro but I have two questions before I choose headlights. Has anyone done an HID retrofit into the non-hid headlight? IF you have please post an output pic against the wall or give me some insight. I can see the difference in the lenses is that the non-HID has the lines all the way across. I wonder if that would affect output much, if any?
Second question is are the lenses glass or plastic?
Im only concerned with the JDM integra headlight, not the USA.
Old Jun 26, 2009 | 09:38 PM
b18c5 power's Avatar
Default Re: HID retro in JDM non-HID headlight
HID in non hid sucks ,really i just put mine back to normal, just buy good bulbs or wait and save your money for the real thing...
Old Jun 27, 2009 | 05:44 AM
sheekdude's Avatar
Contact HidIllusions.com or Customlightz.com... They are retrofit experts, they can help. I actually spoke to them about doing the same thing and they led me in the right direction.
Old Jun 27, 2009 | 09:10 AM
Are you speaking from experience, an HID projector retrofit in the jdm headlights? Im not talking about a HID kit that you can buy for 100 bucks...
the real thing is going to need a retro anyways or atleast a new shield in the projector bc the oem cutoff is for right hand drive
Old Jun 27, 2009 | 09:11 AM
Thanks, which direction did you end up taking?
Old Jun 29, 2009 | 09:02 AM
Mugen Type R's Avatar
If you havent bought your headlights yet, you might as well stack longer for the real Deal OEM HID, youll probably save in the long run in terms of reliability, especially if the install isint done right. Also, a retrofit can be a bitch to do and doesn't give you that OEM look. Whatever you decide to do, make sure you've searched the prices well on H-T for those cause Ive seen OEM HID headlights go for 800 or so on the ITR FS thread BNIB... which means you better have a hell of a good deal on your non hid headlights+hid kit to make it worth your time and effort
Good luck
Old Jun 30, 2009 | 10:20 AM
jcizzo-R's Avatar
OEM HID HEADLIGHTS!
save up.
Output& CUTOFF is WAYYYYYY better than any other. i know, I own a Honda Itr
Old Jul 2, 2009 | 08:31 AM
ahmongboi's Avatar
I've done mine awhile back but still has it on honda tech check it out, but i can tell you don't waste your time on retrofiting the non hid to hid. The non hid lense is just not worth the effort.
here's the oem hid comparing to tsx
https://honda-tech.com/forums/lighting-107/dc2-hid-vs-tsx-hid-lottsss-pic-56k-hang-up-2444408/
here's my first attempt on tsx retrofit before i got the oem hid, havent post up pic of the finish output on the tsx retrofit.
https://honda-tech.com/forums/lighting-107/dc2-oem-hid-custom-shield-lhd-lots-pics-56k-beware-2286024/
and here's the oem hid with a little color spacing.
https://honda-tech.com/forums/honda-acura-28/dc2-jdm-oem-hid-cut-off-pics-2278161/
hope it helps you on making your decision i would just save up and get a oem, it's going for like 500-700 now days. Your black housing non hid is 150 + 300 for complete retro.
Old Jul 2, 2009 | 11:24 AM
Thank you all for the input...
I have no problem doing the retro,...the retro is going to be done either way... the question was would the jdm halogen lense screw the output much...most are saying yes and save up for the real thing ..but the problem is the real thing is RHD, im going to have to make it left hand drive anyways,,, but i am leaning towards the HID headlight+ s2k retro bc of the opposite output
As for the links thank you very much. Judging by the pics, the oem looks to be sharp, do you happen to have a wall shot of the oem dc2 without any mods? Just curious to see the exact sharpness bc i may decide to play with a custom shield myself if it can be as sharp as oem tsx... also, did you find oem dc2 without lense spacing to be wider or less wide than tsx? UR custom LHD shield front shot wall shot in the first link looks about how my color modded tsx did an an eg retro just without the flare...but i think i would want more of a sharper cutoff than color this time, like s2k...i liked the tsx but i want a lil more wider and def sharper
another thing i noticed is that for the HID headlight, the projector design looks similar to s2k,,may make the retro even easier
realis9
Nov 20, 2005 01:33 AM
DC2 to AP2
Apr 25, 2005 12:37 PM
k20z
Aug 7, 2004 09:02 PM
rough_draft
Jun 4, 2004 03:20 AM
