Sparcos
Old Aug 21, 2002 | 02:29 PM
Dirty GS-R's Avatar
New User
Default Sparcos
Do I use all the stock bolts when installing Sparco Torinos because I wasn't given any with the bases or sliders?
Old Aug 21, 2002 | 02:44 PM
norice's Avatar
Default Re: Sparcos (Dirty GS-R)
Can't think of any reason why you wouldn't use the stock ones.
Old Aug 21, 2002 | 03:06 PM
lp3kr's Avatar
New User
i've actually done this in an ek so, i know what i'm talking about. the base doesn't come with any hardware. neither do the sliders.
you need 4-14mm bolts to attach the sliders to the seat. you then need 4 really short bolts & nuts to attach the sliders to the base. i got these from home depot. the base for the ek is actually three pieces that need to be bolted together. again, no hardware was included so, i got these from home depot as well. once that's all put together, you can then use the 4 original 12mm bolts to secure the base to the car. i got the shitty base for the ek with no mount for the factory seat belt so, i had to improvise a little with that.
once you get started & pull the oem seat out, everything'll start to make sense & come together.
good luck.
Old Aug 21, 2002 | 03:29 PM
norice's Avatar
Default Re: Sparcos (lp3kr)
I have also done this (several times unfortunately). Are you sure the bolts are 14mm? I think they are smaller than that - perhaps you are referring to the size of the head and not the diemeter of the bolt shaft? I used M10x1.25 grade 10.9 bolts on my Sparco Evos. To attach the sliders to the base I used M8x1.25 grade 13.9 bolts. Also used self-locking nuts for everything. The metric section of Home Depot (or Orchard Supply) should have these fasteners.
[Modified by norice, 4:31 PM 8/21/2002]
Old Aug 21, 2002 | 04:25 PM
Dirty GS-R's Avatar
New User
Default Re: Sparcos (norice)
Thanks guys. Looks like I have some shopping to do at Home Depot. It's never easy.
bseriesem1
May 29, 2010 08:19 PM
Smash03
May 3, 2008 11:29 AM
Cheesefries333
Nov 6, 2006 04:54 PM
dazcivic
Welding / Fabrication
18
Aug 9, 2006 04:48 AM
TSAngry
Sep 26, 2004 11:06 AM
