94 Accord brake problem
Old Jun 26, 2009 | 11:14 AM
95f22's Avatar
Default 94 Accord brake problem
As stated above, I have a 94 accord with the F22b2. The thing I'm worried about is brake failure. When the car just starts or when it's cold outside, the brakes work fine, but when they get hot I get an extra 3-4 inches of pedal room with no brake response. Front calipers and rear drums look ok on the surface (Haven't taken the wheels off to see), brake fluid is full and master cylinder has no leaks. I've asked around and gotten everything from slave cylinder leak to bleeding the brakes to time to replace brakes. Anyone have a solution/same problem? Don't really want to shotgun parts and hope something fixes it. Thanks for any help.
UPDATE: Just locked my brakes up trying to get into my driveway...no pedal response before. That can't be good.
Old Jun 26, 2009 | 12:05 PM
billyrusa's Avatar
Default Re: 94 Accord brake problem
Possible master cyliner leaks internally. Check the brake line and calipers for leakage. If there is no leak and you are sure there is not air in the brake line, you will need to replace the master cylinder.
Old Jun 27, 2009 | 02:31 AM
alkoholikwun's Avatar
bleed brakes @ no cost, then if that doesnt solve your problem, master cylinder is not expensive.
76 camaro car
Mar 30, 2014 08:02 AM
got.rice?
Suspension & Brakes
Oct 18, 2009 11:36 PM
SikAuto
Jan 31, 2008 03:31 AM
starlily61
Jul 13, 2007 12:38 PM
JZA70
Nov 14, 2006 11:16 AM
