9 inch in the back ?
Old Jun 26, 2009 | 10:27 AM
shimi k20a2's Avatar
Default 9 inch in the back ?
hi guys ..
here is my ek9-k20a hatch =]
lenso BSX 7.5" 16" ET25+
today i'll check the same set in 9 inch offset +20 for the rear in silver.
and pretty love it.. what you guys think.. go for it and change the front rims to silver to ?
need to open a litel the fenders but i want 205/40/16 tires i love the look that
the tire strech on the wheel .. so... to go for it ? =]
Tnx
Old Jun 26, 2009 | 01:04 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 9 inch in the back ?
NO! It's UNSAFE, and a BAD IDEA all around. You're talking about getting tires that are too small for your car, and mounting them on wheels that are too wide for the tires. This generates excessive stress and heat in the tire sidewall, which can lead to tire failure (either popping the bead or an actual blowout). DON'T DO IT!!!
On your '97-00 Civic, you should be using either 205/45-16 or 215/45-16 tires. Tire manufacturers specify which wheel widths tires can be safely mounted on. Most 205/45-16 tires should only be mounted on wheels 6.5-7.5 inches wide, and most 215/45-16 tires should only be mounted on wheels 7.0-8.0 inches wide. Stick to those tire sizes and wheel widths.
shimi k20a2
Jun 26, 2009 10:58 AM
Dgilmour
Apr 29, 2006 03:49 PM
Mr_Moos
Suspension & Brakes
Apr 22, 2006 08:23 PM
tekstyle
Mar 2, 2005 05:56 PM
Fuster_Cluck
Nov 23, 2002 04:56 PM
