DIY - 1994-2001 Acura Integra - Tail light & gasket **PICS**
Old Jun 26, 2009 | 09:29 AM
kroze's Avatar
Default DIY - 1994-2001 Acura Integra - Tail light & gasket **PICS**
This is for those of you who have a lake of water in their trunk/hatchback area everytime it rains It's the tailight gasket.
Tools needed.
- 10mm deep socket, extension, & ratchet.
- Phillips screwdriver
- Flat head screwdriver
- Plier
- Interior clips removal tool
- 8mm deep socket
Start by removing these clips with the body panel removal tool.
Use the plier & pull this clip off.
Now release the seat at an angle & push toward the arrow indicated to get the seat out
Next remove this 10mm bolt
Lift the back end straight up like so and wiggle the seat out.
Here's a picture of the seat's hook for reference.
Open the rear strut cover & remove the 10mm bolt. And use the phillip screwdriver & remove the plastic screw.
Remove this 10mm bolt
Remove these plastic/metal screw with phillips screwdriver
Remove the speaker cover & remove this screw.
Unplug this hatch light & Now you're pretty much done, start pulling the panels out.
Using a deep socket 8mm, remove these (6) nuts to get the tailight out.
Replace it with these OEM tailight gasket. At $25 for one gasket, it's expensive so don't rip or damage it in any way.
Tailights out.
Put the new gasket on and install in reverse order.
airikkCRX
Aug 14, 2010 05:36 PM
confutatis
Apr 10, 2006 08:45 AM
Ckleijne
Oct 29, 2005 11:15 PM
hatchinprogress
Jul 12, 2005 08:54 AM
