Black top DOHC ZC Cam Gear Question
Hello,
I have a Black top DOHC ZC motor. I want to use a set of Skunk2 Pro cam gears on this motor. They dont make them for the DOHC D-series motor. They do however make them for the B_Series DOCH.
Can use these cam gears on there?
you need to use the B-series gears, however, the timing alignment marks for the B are different from the DOHC ZC - the gear on the intake cam will be o.k. using the mark at 9 o'clock to align the gears - the gear on the exhaust cam will be one tooth off - you need to make another mark on the tooth just above the B-series mark at 3 o'clock on the exhaust cam gear and use that mark to align the cams - like this:
I see that those are engine dynamics cam gears.
Even though Im looking at skunk2, I should be able to rotate the time on that one as well to get the same affect?
http://bisimoto.net/store/index.php?...roducts_id=209
SpoonFedEF7
Dec 21, 2002 10:54 PM
