220whp on h22a suggestions/setups
Old Jun 26, 2009 | 08:48 AM
$Tweezy's Avatar
Default 220whp on h22a suggestions/setups
Im putting a h22a in my cb7 and i dont want anything crazy fast or anything, i just want to put 220 to the wheels....i got my bolt ons, aem intake, dc exhaust, ngk 8mm wires...
i had heard that maybe stage 2 cams and cam gears could bring it up a bit? with new springs and retainers of course
please let me know what you think or what youve done....or any reccomendations to reach my 220whp goal.
Old Jun 26, 2009 | 08:50 AM
99 4dr sohc-T's Avatar
Default Re: 220whp on h22a suggestions/setups
buy the adapter plate and put the k20a intake manifold that will bump you up a bit
Old Jun 26, 2009 | 08:55 AM
2point6's Avatar
220 to the wheels will take a little more than cams, but it will help.
What kind of header are you running?
Old Jun 26, 2009 | 08:59 AM
$Tweezy's Avatar
its just a dc sports header...i dont want to **** around with the IM i had enough fun with that already my motor being japanese....
if i get a p28 and get it chipped and tuned or use the p13, what do you think i could gain form that?
Old Jun 26, 2009 | 11:06 AM
tamadrummer1120's Avatar
As said above, cams will help, I mean you could always just build the head up a little, like new valves, or maybe an oversized valve, and a good cam with a nice agressive VTEC crossover. Now of course, unless you are very mechanically inclined (not saying you aren't), I would take it to a shop that can do that kind of stuff, because that can really f*** stuff up if done wrong. And hate to say it, but the IM upgrade would be very helpful as well. If you don't want to put in a new one, at least port the stock one out a little bit.
Old Jun 26, 2009 | 01:15 PM
nus_dogg's Avatar
I've seen the Skunk2 pro1 cams hit from 190whp to 204 with basic bolt-ons.
Old Jun 26, 2009 | 02:19 PM
2point6's Avatar
The last build I did was very mild but made almost 240whp. It was a stock cranked H22 with Type S pistons. My headwork, Skunk2 tuner stage 2 cams, SMSP header, Euro R manifold, 68mm TB, And Hondata S300.
This is a daily driver. I also need to mention that this has trans work done to it as well. It has a Circuitworx 4.7 final drive in it. This does affect the power output.
Old Jun 26, 2009 | 02:30 PM
hdragster's Avatar
3inch exhaust, Race header, Rosko Euro R manifold, Blacktrax Dual stacks, Qsd Rbc manifold, 70mm TB etc. With the correct bolt-on you should hit 190whp+
Old Jun 26, 2009 | 10:51 PM
accord3955's Avatar
i really like this setup....mine was same(as above) crank, pistons and final drive......i was doing on an all leather EX accord with ac and no PS 203 to the wheels on some crower stage 2 all motor cams....and basic bold-ons.....IM and exhaust will make differences....
JE RR
Mar 18, 2017 08:05 PM
Us vs. Them
Apr 16, 2008 07:27 PM
lil big iron 2
Jun 2, 2004 12:29 AM
se93
Nov 2, 2002 12:01 PM
