MPFI manifold question
I tried searching but I couldn't find anything that uses a Y5 manifold. My friend is giving me one and I was wondering if I can use this on my MPFI swap and if I did do I still use the PM6 ecu ? I know its probably a stupid question but I'm confused
try to get a z6 mani, thats what i used and it worked great. You have to use a obd0 throtle body with it tho, if you are going to run a pm6 ecu. idk about the y5 mani..... i would just try to get a Z6 or a A6 mani
You can use the OBD1 TB... just extend the MAP sensor and plug it on the TB... Also the D16A6 TB will not fit the D16Z6... They have a different bolt patter......
thesoundofturbo
Nov 27, 2007 07:23 AM
ExcessiveCRX
Dec 17, 2004 08:36 AM
Iceycrx
Oct 24, 2002 10:57 AM
crx_91si
May 16, 2002 11:41 AM
