AC Compressor Wont Shut Off. 94 Integra GSR
Old Jun 26, 2009 | 06:19 AM
screaminscot's Avatar
Default AC Compressor Wont Shut Off. 94 Integra GSR
I have a 94 GSR. I put a used motor in last year from a 96 GSR. I replaced the compressor with a reman. unit. I went to charge up the system and jumpered the pressure switch,the compressor would not engage. I isolated it to a bad compressor clutch relay( When I tapped it with a screwdriver the clutch enaged)
I replaced the relay with a new one and now the clutch stays engaged even when the ac is switched off in the car. I swapped the relay with another that I know works and it did the same thing.
Any ideas?
lhd dc2
Aug 30, 2010 06:09 AM
screaminscot
Jun 27, 2009 07:02 AM
