Looking to get 88 CRX Si
Old Jun 26, 2009 | 05:22 AM
Riz1's Avatar
New User
Default Looking to get 88 CRX Si
I'm looking at all original one owner 88 crx si with about 125K miles. The car has some rust spots, body is rough, interior needs heavy cleaning. Owner looks like she never washed it/cleaned it. What is this car worth?
If I get it, what do I need to check. Is there an expert I can take it to for pre purchase inspection? I'm going to restore it - need a shop in NJ that can do it. I'm new to this so any help would be appreciated.
Old Jun 26, 2009 | 12:22 PM
teamontherun's Avatar
Default Re: Looking to get 88 CRX Si
You can take it to any reliable shop your aware of in your area. I would check behind the front and rear bumpers for bending. Also check the bumper shocks to see if they are depressed. these would indicate an accident.
Make sure you check all items for functioning. Its all to common to get it home and find out the window wont go up.
Engine oil should be fairly clean and coolant should be green. You can also check brake fluid for cleanliness.
Tires should be usable. Make sure when test driving it that you check for noises and vibrations as these can suggest a bent, broken, or worn out part.
Old Jun 26, 2009 | 02:41 PM
ALLxMOTOR EG's Avatar
Vietnamese!
michael-crxsi
Jul 31, 2010 04:43 PM
461_SS
11
May 22, 2008 12:47 PM
PA MATT
10
Apr 28, 2004 08:12 AM
