CB7 Accord Odyssey 5-Lug Legend Caliper Questions
I have a 1992 Accord DX. I have a set of disc brake rear spindles and I will be buying a set of 98+ Accord V6 rear rotors and a set of 97+ Prelude hub/bearings to convert to five-lug rear discs.
I also want to swap the front to five-lug and I want to have the best brakes I can find in the junkyard. I know the pros and cons to the Legend dual-piston upgrade. I will be using 95-98 Odyssey front knuckles, hubs, and wheel bearings.
1. Which models of Legend have the dual piston calipers? Is it only the ones with the Type-II motor?
2. What five-lug rotors can/should I use? I would like this to fit under fifteen inch wheels if possible. Should I use Legend rotors? 98+ Accord V6?
3. What caliper brackets do I need? 23T? 25T? What cars can I find the correct brackets on?
Sorry for the dumb questions. I have seen plenty of info about the Legend brake swap and info about five-lug conversion, but not much about the two swaps together.
http://www.accordinglydone.com/forum...ead.php?t=1292
Did you read that thread. Seems to have everything you need there. Good luck bro!
jfboy
Jan 5, 2020 11:28 AM
