Turbo H23 Vtec idle issue and stalls Help?
Old Jun 25, 2009 | 05:13 PM
ESP.net's Avatar
Default Turbo H23 Vtec idle issue and stalls Help?
I just got my car rebuilt and fired up. It will stall once I slow down or come to a stop and shut off. Car has Turbo Kit on it just not with the Throttle Body charge pipe on it for break in. I do have aftermarket Vacuum Manifold spliced into brake booster however its hooked up right and zip tied. Just have one nipple going to boost gauge at the moment. ECU is stock jdm p13. Car is obd1... OBD1 H22 injectors.
Car was NA and drove fine no idling or stalling... ideas?
Old Jun 25, 2009 | 06:05 PM
dagle's Avatar
Default Re: Turbo H23 Vtec idle issue and stalls Help?
and you're sure all sensors are hooked up, grounds are good and whatnot?
Old Jun 25, 2009 | 06:50 PM
ESP.net's Avatar
Yup... only does it when I brake and slow down... however vacuum leak would be at idle as well id imagine... wouldn't think my vacuum manifold T from the brake booster would be screwin anything up...
idles fine... when foot goes on brake and slows down... the recoil will stall and shut off...
Old Jun 26, 2009 | 05:04 AM
toomspeed's Avatar
stock ecm? tuned?
Old Jun 26, 2009 | 07:38 AM
ESP.net's Avatar
stock ecu p13 has charge pipe off on TB side and filter placed on...
terik.m
Oct 26, 2008 08:04 PM
righteyeblind
Jul 1, 2008 11:55 AM
iwannaboostmyteg
Feb 7, 2004 10:43 AM
smithbling
Mar 13, 2003 03:49 PM
