1997 suzuka hatch/built turbo
here's the link to the thread 9k or best offer
http://vadriven.com/forums/showthread.php?t=291441
Nice looking car. However, is it REALLY that hard to copy and paste the friggin ad so people don't have to click on a link to see what you have???? IF so, why not give at least a general description so people realize what is done, how much it is, etc.
Well, here's how hard it was. I went to view source then found your post. Copied then got rid of line breaks and changed the pic links to work with this site. Took me a massive 2 minutes. Only reason I know you would have put a link is because you are trying to generate hits for that site. Anyway, here is how your ad should have looked:
Like title says just testing, if the price is right its gone, please keep negtive sh*t to yourself. only thing considered for trade is s2k. Here goes
9000 or best offer
1997 civic dx hatch, painted suzuka blue metallic
carbon fiber knock off rear spoiler
15" balck slips
front and rear 2000 gsr brakes, master cylinder, and booster
2000 gsr front cradle with power steering
2000 si rear sway bar
tokico 5 ways on rear
ground control coil-overs
2000 dash conversion
2000 tailights
si gauge cluster
no ac
custom rear seat delete
shaved ant, emblems,
compustar alarm
now on to drive train
2000 gsr swap
itr lsd
act srteetlite flywheel, clutch and pressure plate
9:1 wisco pistons(stock bore)
eagle rods
all honda bearings clearanced to honda specs by me(i'm a honda tech)
valve job done with new seals on build
supertec springs and retainers
gsr cams, skunk2 gears
moroso oil pan
stainless clutch line
hondata intkae gasket
skunk 2 pro intake manifold port matched to skunk 68mm tb
B&R catch can
rc autoworks ram horn with 3" dp
kteller full 3"stainless exhuast with magnaflow muffler
garrett t3/t04e 57 trim .63ar turbo
38mm tial gate with open dump
precison 1000cc inj
aem fuel rail with b&m regulator
precision 650hp intecooler
tail bov
2.5 inch piping
neptune tunerview2
i"m sure i forgot some stuff, steet tuned on chrome(7lbs) , 750 miles on recent turbo/engine build and over 6k this go, car went 12.73@111 with a shitty 2.0 60ft, so should run 12.4-12.5 on a good pass(and still on low boost)
also have a set of lenso's and 24.5/8 slicks if price is right and neptune rtp( not going to sell seperatly)
the bad: needs a new hood and front bumper is cracked
contact via pm
9000 or best offer
15" balck slips
2000 tailights
si gauge cluster
no ac
compustar alarm
2000 gsr swap
itr lsd
eagle rods
moroso oil pan
B&R catch can
precison 1000cc inj
tail bov
2.5 inch piping
neptune tunerview2
contact via pm
