obd1 jdm SOHC f22b into obd2a '97 CL - what dizzy?
Old Jun 25, 2009 | 02:40 PM
eohagan's Avatar
Default obd1 jdm SOHC f22b into obd2a '97 CL - what dizzy?
this swap has taken like 3 weeks now (mostly by myself) and I'm going nuts.
fuel, no spark. motor has no CPS / CKP sensor, harness does.
I have jdm (more wires doesn't plug in) and usdm (doesn't give spark) dizzys, can I go buy something at autozone like an obd1 accord dizzy and be in business with the CPK trick from ff-squad? Do i have to extend a bunch of wires or buy an expensive-*** obd1-obd2 harness, change ECUs or what?
thanks in advance fellas I'm so tired of this swap :D
Old Jun 25, 2009 | 04:18 PM
nus_dogg's Avatar
Default Re: obd1 jdm SOHC f22b into obd2a '97 CL - what dizzy?
I read somewhere that you'll have to transferr all the crank angle sensor, oil pump housing, etc. I may be wrong but there's a guy on the net that had to do this for his JDM F22 motor before it wouldn't start. Research more about this though.
Old Jun 25, 2009 | 05:49 PM
accord3955's Avatar
OBD-2 car are gay(personal opinion (no ofence)).....therefore if you dont want to get into wiring problems buy a harness convertion....if you are really into wires.....look for the hayness book or helms book of the motor first and then the car(or vise-versa)....then do your own harness convertion.....all i can tell you is that OBD2 crank sensor is by the crank pulley and for the spark part....losen up you dizzy and ground it up some how so you can rotate the camshaft side then unplug the spark plug wires and then plug a sparkplug to it to see if it spark.....then rotate than dizzy manually to see if the spark plug spark....if it doesnt than it could be wires or rotor or dizzy cap.......... good luck
Old Jun 27, 2009 | 07:47 AM
eohagan's Avatar
will i ever pass Cali smog if i go obd1?
Old Jun 27, 2009 | 11:07 AM
accord3955's Avatar
with your oem CAT or a good after market one your be set to go....
Old Jun 28, 2009 | 12:57 PM
eohagan's Avatar
The ca smog ref I spoke to said this would be a same - for - same swap, so a replacement, since I did f22b for f22b1 ... But obviously the obd1 tech is older how am I going to get by?
em1si5853
Dec 26, 2009 11:45 AM
B16acivicsedan91
10
Nov 11, 2009 12:23 PM
Prudz_lude
Dec 14, 2008 11:45 AM
