B Series Turbo Kit, Alot Of Random Parts, Suspension ETC . .
The following is for sale . . . Will ship these items under terms listed below. Other wise LOCAL Pick Up In Central NJ
B series Turbo Kit- SOLD
2000 Integra GSR Dual Bend Shifter-$35
2000 Integra GSR Stock Springs-$40
OEM 2000 Civic SI Transmission Mount Bracket-$25
OEM SOHC Civic Rear T Bracket- $20
OEM SOHC Hydro Clutch -$40 got decent life left never slipped
OEM 92-00 Civic SOHC Hydro 5 Spd Starter-$40
B series into EG Trans mount- SOLD
98-01 Integra Clear Bumper Lights New- $20
Competition Engineering Fuel Sump BNIB-$50
Holley EFI External Fuel Pump With Fram Filter-$75
94-01 Integra Rear View Mirror-$15
94-01 Integra Drivers Side Motor Mount Post- SOLD
90-93 Integra 5 Spd Cable HalfShaft-$50
OBD1 Engine Harness, Not hacked up or anything Non Vtec-$60
B Series into EG Drivers Side Mount ( 3 Bolt Integra)- $25
B Series Into EG Rear T Bracket- SOLD
Neuspeed Green Springs All 4 ( Front 2 Are On EK Struts Rear On Nothing)- $150
Integra Type R BRAND NEW SPEEDO (Not Cluster Just Speedo)-$120 OBO
Wideband o2 Sensor With Wiring Clip (Not Sure For Which Wideband)-$30
Integra Fuel Filter With Bracket (No Line)-$15
B Series Hydro Clutch Fork-$15
93-97 Del Sol One Piece Gunmetal Housings- SOLD
The yellow fogs in the pic above ( There not oem or for a del sol but they fit on the sol and more then likely will fit 99-00 EK Fronts, They were ion blue but painted with the yellow spray)- $30
PARTS WITH NO PICS !
2000 Integra GSR Final Drive and First Gear-$75
2000 Integra FBP Stock Wing MINT-$50
2 1/2" 4 bolt downpipe with o2 bung-$60
AutoMeter 5" Phantom tach (White Face, Mounting Band $11)- $100MINT
OEM Civic Del Sol Shifter ( If you dont know its a really short throw shifter with a bend towards the driver, Not like Egay ****)-$35
OBD1 P06 ECU-$40
OBD1 P75 Chipped On Crome-$110 (For an extra $20 I will include a basemap)
SOHC Hydro Axles- $50 For Both
90-95 Integra LS Valve Cover Have 2 (1 Stripped to bare metal)-$25
2.5 Inch 4 Bolt Downpipe-$45
Tial 14lb Wastegate Spring-$15 (New)
Tial 38mm Fire Ring (AKA Valve Seal, NEW)- $20
SOHC Hyrdo Clutch Fork-$15
Civic Single Cam Shift Linkage-$30 With Stock Shifter
92-95 Civic 94-00 Integra Stock OEM Shift Boot (Clean)-$10
93-97 Del Sol Console Vents- $10
93-97 Del Sol Tail Light Garnish USDM Milano Red (MINT)- $40
( The metal part the licence plate mounts to)
92-95 Civic 3Dr/Coupe Sideskirts (Black Primer, good condition)-$35
98 ITR Black Carpet (Good condition, needs a cleaning, clutch pedal area is fine)- $65
These parts can be shipped if the buyer is willing to pay, Or can be locally picked up in Central NJ.
Will trade for
93-97 Del Sol Drivers Side Fender Any Color
JDM Del Sol Climate Control
OBD1 P06 ECU-$40
Will trade for
DownShiftPerformDC2
Jul 21, 2009 01:32 AM
DownShiftPerformDC2
Northeast (Sales)
32
Jun 27, 2009 11:06 AM
