tial wg special
Old Aug 21, 2002 | 12:28 PM
b18bturbo's Avatar
Default tial wg special
Tial WG 35mm special 236 shipped for the STD units with dump flange
Tial WG high pressure 35mm 256 shipped with dump flange. most colors
Tial BOV most colors 200 shipped.
[Modified by b18bturbo, 1:24 PM 9/4/2002]
Old Sep 4, 2002 | 10:24 AM
b18bturbo's Avatar
Default Re: tial wg special (b18bturbo)
up
Old Sep 4, 2002 | 10:37 AM
TurbothisLS's Avatar
so a normal silver tial wg is $200 shipped?
how about pickup?
thanks
Old Sep 4, 2002 | 10:44 AM
b18bturbo's Avatar
Default Re: tial wg special (TurbothisLS)
tial BOV is 200 shipped not the wg.. the wg is 236 shipped with dump flange pickup is 236
Old Sep 4, 2002 | 10:59 AM
legendboy's Avatar
I'm bookmarking this for when I have some $$, your prices are
Old Sep 4, 2002 | 11:41 AM
symba's Avatar
at what point would you recomend the high pressure 35mm tial versus the reg 35 mm?
Old Sep 4, 2002 | 11:50 AM
The_Head's Avatar
Default Re: tial wg special (symba)
Old Sep 4, 2002 | 12:23 PM
b18bturbo's Avatar
Default Re: tial wg special (xThexHeadx)
I reccommend ussually any system that constantly runs around 20-30 psi daily shoudl require the 35mm high pressure unit else no need.
Old Sep 4, 2002 | 12:33 PM
symba's Avatar
thanks....this it OT but can you get an h23a1 block along w/pistons rods and have it resleeved? I'm having a hella time finding an h23a block..
Old Sep 4, 2002 | 01:07 PM
BROOD's Avatar
B18Bturbo; Tial BOV $200 shipped with either the alloy, SS, or steel flange? Or extra for different flange?
Old Sep 4, 2002 | 01:18 PM
b18bturbo's Avatar
Default Re: tial wg special (SLPR)
stainless steel flange..
Old Sep 4, 2002 | 01:19 PM
b18bturbo's Avatar
do you just need th block or what..
Old Sep 4, 2002 | 01:43 PM
symba's Avatar
Yeah, I need the block..That's all I have money for right now...But by next month I'll need the pistons and rods also
Old Sep 4, 2002 | 02:02 PM
Mikey3000's Avatar
the 35 mm can handle 20-30 psi? what's the use of them having the 46 mm then? if all i need is the 35 mm i'll buy one soon.
Old Sep 4, 2002 | 02:15 PM
b18bturbo's Avatar
Default Re: tial wg special (Salvatore Leone)
46mm is needed in racing applications.. not on street driven car.. The 46mm is really only required if you drive with larger turbos that need alot of exhaust gas to evacuate.
Old Sep 4, 2002 | 02:20 PM
Mikey3000's Avatar
i'm gonna be running a T04X on a full race h22 motor (20 psi). which wg do you think will be best?
Old Sep 4, 2002 | 03:38 PM
HybridKOOP's Avatar
Viren... any idea what Inlinepro's T4 manifold that they just started making is flanged for (wastegate)? If it's flanged for the standard 35mm I'll be all over that high pressure ordeal.
Old Sep 5, 2002 | 09:43 AM
hondaswaper's Avatar
Default Re: tial wg special (HybridKOOP)
how much for a 46mm? thanks
Old Sep 5, 2002 | 09:46 AM
b18bturbo's Avatar
inline pro mani folds are flanged for 35mm....
the 46mm units are 505 shipped.
Boostfed
Nov 29, 2012 07:56 PM
b16ajdmrex
Apr 16, 2011 06:10 PM
Synapse Motorsport
Feb 13, 2006 04:52 PM
