CRX + Z6 + Hydro trans question
Posts that say "just use a cable si trans" or "stick with obd0" or "use a cable vss" or "get overpriced billet aluminum mounts" will be ignored.
With that said the situation is this... I have a crx I'm building. I already have made a clutch MC bracket for under the dash that part is done. I've redone the car harness, grafting obd1 plugs onto it. Now, I want to put the turbo Z6 and hydro trans from my 94 in it with an integra cluster for the electronic vss stuff. My question is this: what mounts should I use for this setup that will be as cheap as possible? I want experience from someone that has done this. Will the stock crx rear trans mount and drivers side engine mount fit? The thing I would have to deal with then is the passenger side trans mount. I can modify the hydro EG trans mount I have that's not a problem, I just would rather cut and weld 1 mount than all 3 if I have a choice.
Canadian_EF
Apr 7, 2013 02:39 PM
WayFastWhitie
Dec 18, 2004 05:57 PM
