96 turbo hatch for sale,philly
https://honda-tech.com/forums/showth...8#post39031228
theres all the info and pictures about the car im firm in the price so dont bother tring to low ball me, no trades unless its a s2000
heres is whats on the car
corbeu seats
jdm air bag delete
plx-300 tuner
5" tachometer
oil and boost gauge
battery relocated to the back using the summit relocating kit
roll cage (not installed)
blox tuner b cams
supertech valve,spring and retainers
the head has been port and polish in the area of the bowls
gsr tranny with quaife,carbon syncros and all gears new
act extreme pressure plate with 6 puck clutch
eagle rods with cp flat top pistons stock bore 81mm
full race ram horn manifold
garret t3/to4e 57 trim
intercooler piping made in aluminum al the way around 3"cold side 2.5"hot side
3"inch downpipe
t1 catchcan with all fittings working in order
innovative mounts with solid grey compound polished
drag racing wheels with nittos drag radial up front azenis in the back
ksport 36 way adjustable suspension
skunk2 front studs with lug nuts all the way around
si cluster in perfect working condition
tunes with hondata s300 making 518 hp at 18psi car run on the 2nd pass 11.3 with full interior and got kicked out the track
asking 10,000 got most of the receipts on hand
corbeu seats
jdm air bag delete
plx-300 tuner
5" tachometer
oil and boost gauge
blox tuner b cams
3"inch downpipe
Boner_Ben
Sep 10, 2006 12:27 PM
