Type1 vs. Toda header?
ok, so i noticed that IPSracing has the type 1 header for like 575 or so right now, and i was looking at the header test overlay between the 2..so my question is, which should i get? i was going with toda all the way, but if the type 1 is so close and nearly hald the price, which would you guys recommend? help me out a little guys, will the toda header be beter in the long run? thanks..
Both are good high quality pieces, If your going with some big cams I'd most likely suggest the Toda. If money is tight the T1R is good, but if you have the extra money for the extra hp then its Toda
smokinloc
Oct 13, 2010 09:11 AM
903
Jul 9, 2006 04:23 AM
