HOW DO I WIRE UP THE FREAKIN' HORN!!! (pics)
Ok so here's my problem. I have been trying to install a Grant steering wheel on my EF sedan. I went out and bought the Grant wheel, and the Grant hub installation kit. Now I will post up some pics of my installation progress and will someone please tell me what I am doing wrong! Thanks in advance...
^Ok, here is my first step, I installed this thing on^
^Then my next step was to install this piece^
^Then this^
^And now this! ta-da^
^This is what the back of my horn looks like, I know the one with the ground symbol goes to the ground but what does the other terminal connect to?!? I'm so lost... I did search but didn't quite find what I was looking for, I also checked the fuse and it's good, please help me...
^Then this^
if you touch that dangling wire to one of the bolts on the hub it will go off...
you need to run a wire with a spade terminal tucked under one of those bolts to the horn
To anybody who has this problem in the future, listen up! I found out what my problem was. If your horn button has 2 terminals behind it and one is for the ground and the other is hot, you run a wire from the ground on the horn button to the blue/red stripe wire on the steering assembly, and the other terminal on the horn button goes to anything metal.
redsidriver
Jun 2, 2010 09:35 PM
2001B18C1GS-R
Oct 27, 2007 03:08 PM
Lamska
Jul 8, 2004 05:45 PM
