dpfi to mpfi
Old Jun 25, 2009 | 05:55 AM
KDvtec5757's Avatar
Default dpfi to mpfi
ok i was reading about this i just need to no when im doing this i take the plug off my stock dx motor and us it on the dx i just wire it how the wrieups say and plug it in
Old Jun 25, 2009 | 10:27 AM
jlicrx's Avatar
Default Re: dpfi to mpfi
http://www.fourthgenhatch.net/mpfi.html
Old Jul 7, 2009 | 08:08 PM
91-hatcherz's Avatar
question? if i just wanna swap my dpfi to mpfi with non-vtec throttle body is it hard cause i am prolly getting a parts car but its not an si model just a dx i belive. so is it hard to swap throttle bodies to my 91civic cx? all have all the stuff to swap off a runnign car so what will i need to make more power with the parts cars motor to mine?
Old Jul 8, 2009 | 06:34 PM
uberEFtuner's Avatar
Both of your questions makes no sense. Please rephrase that.
Old Jul 8, 2009 | 06:44 PM
im sorry i was quite tired last night. i wanna know if theres a thread or sumthing out there to show me ho to convert my dpfi motor to mpfi if i have my parts car for it, its also a non vtec swap.
Old Jul 8, 2009 | 08:08 PM
D16SiHatch's Avatar
someone already posted a link above, but here's another good link for dpfi to mpfi info.
http://hondaswap.com/swap-articles/d...writeup-49557/
Old Sep 16, 2009 | 08:39 PM
efnborder's Avatar
I just did the dpfi to mpfi swap with a d16z6 but found out laiter the write up i used was for a dohc zc did i mess it all up? it runs now but has a miss and wont rev past 3k. ANY ONE able to help me??
Old Sep 16, 2009 | 10:10 PM
EFDumpster's Avatar
Yeah your car is now in limp mode so it wont damage its self.. there could be 1 of 2 things wrong here either u have a bad injector or wire is not giving the injector power or your crank position sensor is fualty... thats all i know about the cars ecu putting its self in limp mode and not going past 3k
Old Sep 18, 2009 | 09:01 PM
efnborder's Avatar
which 2 ports on the p28 ecu do you jump to read the codes???
Old Sep 19, 2009 | 08:11 AM
EFDumpster's Avatar
Ok on EFs there is a light inside the ecu but since your car is swaped and your using the p28 there is a plug either under/behind the glove box that u can jump with a paper clip an then turn car to the #2 ignition spot and the check engine light will flash corisponding the code number there is a link somewhere on honda tech that tells u the correct way and codes to do it!
Canadian_EF
Jul 11, 2009 01:14 PM
furiousbob
Apr 8, 2006 09:02 AM
dropd4door
Jan 25, 2003 09:38 PM
strykr
Mar 22, 2002 12:49 PM
