91 honda crx si (ZC?)
i have recently bought a crx that has a zc motor swap and the only thing i on the block stamp says is zc how do i find out which zc motor this is i need to replace my timing belt BAD and need to no what to order it for but having no luck finding out even what the motor came out of if anyone could help i would apprciate it thanks slick
ok you may want to check out thezcr.com
they have a parts list there for you to get all the items you need to rebuild your engine. its where i found all my info long before i even thought about getting a dohc zc, which to this day, i may be getting on saturday lol.
well it came out of a JDM 88-91 civic/crx. but there are different versions of the engine that came in later years as well. knowing which one you have is the biggest mystery of all. i do know that for a timing belt you need an 88 prelude 2.0 si belt.
heres a link to a downloadabel pdf file for the parts list.
i eventually want to convert it to a 5spd but that will be a while since i have nowhere near enough experience. what performance upgrades would anybody recommend for starters other than a cool air intake?
for this zc engine all you have to do is go to the parts store and look up parts for an 88 acura integra with a 1.6.
this will give you all the right parts for your dohc zc.
not true - for the OBD0 DOHC ZC, most all of the parts below the top of the block, except pistons, are the same as 88-91 CRX/Civic Si D16A6 - parts above the top of the block are the same as 88-89 Integra D16A1 - timing belt is same as 88 Prelude 2.0 Si - some parts are the same for both D16A6 and D16A1 - some parts, like bare cylinder block, bare cylinder head, valve cover, timing belt covers and timing belt gear on the crankshaft are unique to the DOHC ZC
well i know i need a new tranny cuz it wont shift past second. but i know that oil shouldnt be on the spark plugs but i wasnt sure of what it could be. how many gaskets come in the set?
