timing belt
Old Jun 25, 2009 | 03:43 AM
cvc1393's Avatar
Default timing belt
how much is one.
how hard is it to put on?
Old Jun 25, 2009 | 05:09 AM
dephtone's Avatar
Default Re: timing belt
Usually about 30-40 bucks.
Pretty easy if you can get the crank pulley bolt off lol. You will probably need an air impact, electric ones usually don't cut it or if you have the tool from Snap-On.
Old Jun 25, 2009 | 06:35 AM
Axle Raynes's Avatar
exactly what do you need to do to change the timing belt?
Old Jun 25, 2009 | 06:57 PM
cvc1393's Avatar
some guy was selling his crx and it needed a timing belt
Old Jun 25, 2009 | 07:04 PM
D16SiHatch's Avatar
if he sold it cause it was broken and thats why it needs a belt.. then most likely the engine is trashed. now if its just old and needs replaced then thats another story.
this is for a 92-95 civic, but its going to be virtually the same.
edit: forgot that it also has how to for the waterpump at the end of it as well lol
Old Jun 25, 2009 | 07:05 PM
mjshealy's Avatar
Icon6 Re: timing belt
remove all accessories and belts from the motor, remove the driver side engine mount, remove the FL wheel, remove all parts of the timing cover, rotate crankshaft to TDC, remove crank bolt(HARD), loosen timing belt tensioner, rotate tensioner to relieve stress on timing belt, line up crankshaft notch with oil pump arrow, make sure the camshaft sprocket didn't move(UP should be facing up, and the two horizontal lines on the pulley should be lined up with the top surface of the cylinder head),install new timing belt, make sure everything is lined up again, tension the belt again(forget if it's three notches clockwise or counterclockwise?), reassemble.
That's it in a nutshell. Don't do it if you are sketchy, you'll be buying a new motor... or at least a new head.
Old Jun 25, 2009 | 07:07 PM
mjshealy's Avatar
wow...me and the guy above posted those at the same time...lol. His is a lot better though...
halocore
Mar 30, 2009 09:05 PM
integra3586
Sep 25, 2006 03:57 PM
teler86
May 18, 2006 06:29 PM
Civic4ever
Oct 7, 2004 10:08 AM
Spade
Acura TL, RL & ZDX
Jan 1, 2004 06:26 PM
