DC5/Type S Steering wheel on DC2?
Wondering if anybody has put a steering wheel off an RSX Type S on a DC2 Integra? Does the SRS wiring plug and play? Do you need a special hub adaptor? I did a search but couldn't find anything. I have read they will fit Ek Civics, but I was pretty sure that EK and DC use differnt hubs..
Any info would be great!
Thanks
Thanks
The DC5 and DC2 have different splines for the steering wheel you'll have to swap the steering column out to match the new wheel. The EK and DC5 share the same splines and the EK and DC2 steering columns are interchangeable.
Thanks for the response. Instead of the DC5 wheel, I will just go with an ITR SRS wheel. That seems like a bit less work than switching steering columns. Thanks again man, I appreciate the quick response.
Kip
Kip
Miami Honda
10
Mar 13, 2012 06:39 PM
