89 crx in 90 crx si idle realy high need help
hey guy i have a 90 crx si and i took the motor out to get it re built and put in a 89 crx dx motor in the motor is dpfi so i put my si man on it so its mpfi and will plug in to my car but it idleing at rev what do i need to do is it ecu pins that need moved and if so what ones or what would it be
most likely a vaccum leak. start looking around and searching for something unplugged. or it could be that its not sealing at the cylinder head. did you reuse an intake manifold gasket?
