What size Azenis to go with?
I currently ordered 16x7 +25 offset 4x100 Volks and I have brand new Falken Azenis size 205-40-16's.......However, I ordered that side because since my offset is low, I didnt wanna deal with the issue of rubbing. But on the other hand, I feel like the sidewall 40, is too thin n may cause the wheel to bent etc. So I was thinking about selling my 205-40's n go with 215-45-16's instead.. but I dunno if my offset will allow me to go low since it may rub with the 215-45's....What tire size should I go with? any help is much appreciated
BTW my fenders are already rolled and the wheels will be goin on a DC2.
205/45-16 and 215/45-16 are usually the best 16" sizes on an Integra. I don't know whether that offset will cause problems, though. (However, I'm not a big fan of doing a second thing wrong to try to compensate for doing something else wrong, like getting the wrong tire size to compensate for using the wrong wheel offset.)
Thanks for your advice ......215-45''s are deff an integra size, but in my case im still not sure it it''ll work like I would want to with my wheel size. Anyone else has any input on this?
If you want a little more clearance than 215/45-16 gives you, you can get 205/45-16, which will work equally well on an Integra and give you a bit more clearance. (Both sizes are within 1 percent of the stock size in diameter; 215/45 is just under 1 percent larger, and 205/45 is just under 1 percent smaller.)
Sticky tires (even stickier than the Azenis) available in 205/45-16 include the Bridgestone Potenza RE-11 and Toyo R1R.
Thanks for helping me out man ..... I sold my 205-40-16's las nite to a buddy and ordered 215-45's Azenis
should get them in 2-3 days...... I've been looking at pictures of that specific size tire n it deff suits how I want it to look with a thicker sidewall...I'm not going for the slammed look either just low enough so that the tire doesn't rub with the fender
