Brake light and abs light come on while driving
Old Jun 24, 2009 | 04:19 PM
DC-2guy's Avatar
Icon2 Brake light and abs light come on while driving
about a week ago my brake light started coming on while i was driving, i could'nt figure it out and now when i start driving both my brake light and abs light come on even the abs is working and the brake lever is all the way down. anyone know where i might start looking to see if i cant get this issue resolved?
Old Jun 24, 2009 | 06:33 PM
rhino87's Avatar
Default Re: Brake light and abs light come on while driving
My brake light did the same thing. I noticed it only came on at night, and it would go off on its own, after driving for 15-20 minutes. I don't know why that happened but it also stopped happening like 5 months ago. I didn't change anything or attempt to fix it.
About the ABS light, I would check the code. See the FAQ section for instructions on checking the code.
Old Jun 24, 2009 | 06:50 PM
Hydro_Da's Avatar
what chassis is this happening on? cause it happens to my da as well. i'm assuming you guys are talking about the hand brake light in the cluster right? when i drive at night it will come on randomly or flicker, sometimes it dims on its own. any suggestions?
Old Jun 25, 2009 | 07:00 PM
DC-2guy's Avatar
the problem is happening on my 97 dc-2 and my brake light comes on as soon as i start driving and stays on until i restart the car.
Old Jun 25, 2009 | 11:15 PM
slaya's Avatar
the most common problem with the brake light is that often the fluid level gets low and when you turn and drive it trips the brake light to come on.
Old Jun 25, 2009 | 11:23 PM
LOVEthatDC2's Avatar
for the abs light, check to make sure the connector (metric 10 bolt) at the battery terminal are tightened properly. mine was loose and the abs light would come on and go off randomly due to the bolt being loose
lakers4life
Aug 10, 2014 12:44 PM
daddy
Honda Civic (2001 - 2005)
May 29, 2007 09:02 AM
gurlracer_camille
Dec 10, 2006 10:56 PM
HONDA_TYPE_R
Nov 30, 2004 01:04 PM
monalisa overdrive
Feb 15, 2004 05:07 PM
