d4 bulb on 01 not the same as 98-99 help
Old Jun 24, 2009 | 12:14 PM
blinklit's Avatar
Default d4 bulb on 01 not the same as 98-99 help
ok,well i go to the dealer to get my last bulb (i hope) and there is a 73 yr old man with a bad d4 bulb in his 01 accord 4cyl trying to get a new bulb and they tell him they need to order the bulb and it will be $98 to replace it.
i said i have the bulb at home and didn't need it so he could have it,he then asked me if i could replace it too,yup,no problem will take me about 5 min. to do................WRONG.
although they look the same,once removed the circuit board was different,bulbs were different and there is no way i could figure out how to get to the p/n/r/d4 etc...bulbs.i removed everything but still could not get the board to come off.do you need to remove the needles from the fuel and temp gauge,or all guages to remove the board.
i feel like a tool not being able to help this guy and then to make things worse he starts to tell me his wife died 6 months ago and 2 months later his 43 year old son was diagnosed with cancer and died weeks later.now i feel like a used tool and want to help this guy out with what seems to be a simple problem so if anyone can give me advice on this replacement i would appreciate it.
thanks.
Old Jun 24, 2009 | 05:18 PM
alkoholikwun's Avatar
Default Re: d4 bulb on 01 not the same as 98-99 help
are you having problems taking out the cluster?
$98 to replace (install?), or just for bulb.
Old Jun 24, 2009 | 07:25 PM
blinklit's Avatar
$98 to remove the cluster,replace the bulb and then re-install the cluster.
i removed it and on mine i have a row of bulbs with black bases that 1/8 turn in right there.just a twist and they come out.on the 01 the p/n/r/d4 etc... is a solid board,they seem to go in from the front rather than the rear.
Old Jun 24, 2009 | 08:00 PM
Targa250R's Avatar
be professional
For 6th-generation Accords, there are two different gauge cluster manufacturers depending on year and model - one is Ford (found in most V6 models from what I've seen), and the other is Nippon Seiki (more common in 4-cylinder models). Each one takes a different type of bulb for the PRND indicator tree.
Old Jun 25, 2009 | 01:39 AM
blinklit's Avatar
so the question is how do you access the pnrd tree on the nippon seiki cluster.
i have the ford model wher all bulbs are easily (and repeatedly) replaced.lol
and on the same topic,somewhat,his fuel gauge was still a bit over 1/2 when out of the dash,i have a feeling that is not right?mine and other vehicles i own always return to "E" when off or no power.
oh and btw,thanks for the replies so far.
DarkStreetRacerX
Lighting
Sep 24, 2007 06:50 AM
Zion-I
Jul 16, 2006 09:34 PM
exile29
Sep 10, 2005 09:51 AM
GrimeyAccord
Jan 18, 2005 07:32 PM
EleanoR
Sep 6, 2001 07:15 PM
