Obd1 distribuitor necessary?
Old Jun 24, 2009 | 10:06 AM
ricardo13d's Avatar
Default Obd1 distribuitor necessary?
i have a 90 crx whit b16 obd0 swap, the wyring conversion harness obd0 to obd1 ecu. my distribuidor is obd0. to install a obd1 Ecu its necessary a obd1 distribuitor? can do another adaptation? thnks.
Old Jun 24, 2009 | 10:09 AM
dephtone's Avatar
Default Re: Obd1 distribuitor necessary?
you MUST use an OBD1 distributor if you convert over to OBD1 at the ECU. OBD0 distributor will not work on a obd1 ECU as they are wired differently.
Old Jun 24, 2009 | 10:27 AM
ricardo13d's Avatar
and obd2 distribuitor can be used?
Old Jun 24, 2009 | 10:53 AM
D16SiHatch's Avatar
sure can. just swap over the obd1 plugs.
Old Jun 24, 2009 | 10:56 AM
ricardo13d's Avatar
ok thnks. i know if i can use the obd0 ICM on obd1 or obd2 distribuitor?.
Old Jun 24, 2009 | 11:01 AM
D16SiHatch's Avatar
do you mean ecu? you cannot use an obd0 ecu with an obd1/2 dizzy. and vice versa
Old Jun 24, 2009 | 11:05 AM
ricardo13d's Avatar
no, i mean ignition control module of an obd0 dizzy on obd1 or 2 dizzy.
let me explain, i have a obd2 dizzy whitout ICM, and want to install the obd0 ICM. i can do it?
Old Jun 24, 2009 | 11:12 AM
D16SiHatch's Avatar
i dont believe they are interchangeable
Old Jun 24, 2009 | 11:18 AM
raene's Avatar
Ignitors are interchangeable.
Old Dec 8, 2011 | 06:08 PM
MISTAGLOCK's Avatar
reviving a thread from the dead lol but the icms SHOULD be all interchangable. tonite i decided to rip apart my obd1 dizzy and install a NEC OBD0 ICM and it fired right up and works.
Old Dec 8, 2011 | 06:52 PM
KINGVEM^^ED6's Avatar
GOOD IDEA!
Old Dec 8, 2011 | 06:55 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
I already gave my retort in the other threads he is reviving...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/will-icm-95-civic-fit-91-civic-2985340/
efiliated
Jun 6, 2011 04:04 PM
mymeatb18"
Oct 3, 2006 04:58 AM
91dxcrx
Jan 22, 2006 05:46 PM
ViperRedCRX
May 19, 2003 01:01 PM
